Old 09-19-2011, 10:55 PM
shelby78 shelby78 is offline
Vehicle: 2011 ram 1500 4x4
Trim Level: sxt
Rep:29
shelby78 is on a distinguished road
Default Allignment after 5100 install number's.
I installed belstein 5100's a while back and said i would post the allignment number's. I got lazy but finally got around to it. Here is the sheet. It was out quite a bit even though the number's don't look like it.
I think i gained about 25 percent braking after the allignment also. Get it done if you lift or lower.
Old 09-20-2011, 12:55 AM
AzHunter's Avatar
AzHunter AzHunter is offline
Vehicle: 2006 Dodge Ram Quad Cab 4x4
Trim Level: LARAMIE QQ 4x4 3.92
Rep:52
AzHunter will become famous soon enough
A must if you do anything to the front suspension.
If i can kill it with an arrow, I'll eat it.
Bilstein 5100 install. Pic heavy. 2011 ram 1500 shelby78 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 38 11-12-2013 10:37 PM
vibes in 4x4 after bilstein 5100 install platinuminjected Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 80 12-28-2011 05:55 PM
Air Lift 1000 Install on '11 Sport with 2/4 drop... TerryH Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 18 08-27-2011 11:41 PM
08 Double Din install detailed modified stock bezel ttconvert2001 Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 08-14-2011 10:51 PM
Mopar Parts numbers for Install Kit??? BigGirlToys Electrical 3 12-22-2010 01:55 PM
