Old 09-20-2011, 02:06 AM
GolfSIX GolfSIX is offline
Vehicle: 2010 Ram 1500 QC
Rep:25
GolfSIX is on a distinguished road
Default -12mm offset
Does anyone know if I can run a -12mm offset on my stock 2010 ram 4x4? Tirerack has the ATX Justice on close out. Im looking at the 18x9 wheels.
Si Vis Pacem...
Old 09-20-2011, 06:30 AM
daggertats daggertats is offline
Vehicle: 2011 ram reg cab 4x4
Trim Level: st
Color: deep water blue pearl coat
Rep:14
daggertats is on a distinguished road
not sure if ya can or not but that offset is gonna pull the wheels outward so they wont be tucked under the wheel wells anymore
Old 09-20-2011, 11:17 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
My Drag Radials are mounted on -12 offset 17x9 Moto Metal wheels,
You'll probably want to invest in some Bushwacker pocket flares to protect the side of your truck.
Tires are 295/45R17 Mickey Thompson Street ET's and stick out about 2"-2.5"
My 305/50R20's on 20"x 9" stock wheels with +19 offset are only out about a 1/2"
Old 09-20-2011, 12:17 PM
DMG698's Avatar
DMG698 DMG698 is offline
Vehicle: 2012 Dodge Ram 3500
Rep:17
DMG698 is on a distinguished road
Ya they will work, i have only +1 offset on my fuel hostage rims. i have 325/65R18 and they stick out an 1" and i have no rubbing issues. you'll be safe with -12 offset but like the guys said you will have to invest in flares as well
18x9 offset sweet spot for 305/60/18? cyberpine Dodge Ram Wheels And Tires 7 04-19-2013 05:31 PM
What width tire can I fit for an 08 with a 17x9 0mm offset? 345cube Dodge Ram Wheels And Tires 2 04-05-2011 02:14 PM
2wd with 20x19 with -12mm offset - too out? cyberpine Dodge Ram Wheels And Tires 4 10-17-2010 10:43 AM
wheel offset? 1badram Dodge Ram Wheels And Tires 2 07-09-2010 12:09 PM
17" wheels off for new dodge. DODGE4x4 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 11-25-2009 03:28 AM
