tonneaucovered.com
Old 09-20-2011, 09:32 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Default Liquid Masking / Painting Emblem
So I started on my rear tailgate emblem with this stuff called masking film...basically plasti dip in a jar that brushes on....
Coat whatever you are working on, cut out the area you want to paint and peel it away......the rest is left covered. SOOOOO.....
I did that and cutout the black background to paint....looks awesome! Start sanding, painting and cleared it.....Let it sit for half the day or so. Went to peel the mask off, and this is what I got!!!!
Obviously not what I was looking forward to! SO now I don't know what to do with it! It will be super hard to sand....I am re-masking it now to see if I can fix it at all.....the lines aren't the greatest. If this doesn't work, I might try sandblasting it and painting the whole thing....Any ideas or suggestions from any maskers out there???
Old 09-20-2011, 11:50 AM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:215
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Take sandpaper/steel wool and wrap it on a small dowel, stick and sand where you want the paint to stick, use a cotton swab with acetone/laquer thinner to clean the area then spray it. The black part needs to be roughed up to hold the paint. dont get the liquid mask on it or it may not come off after its roughed up.
Mike
Old 09-20-2011, 11:52 AM
sonocativo's Avatar
Rep:215
Or you can maybe float the paint, where you fill the area you want painted with paint and let it level itself and set up.
Mike
Old 09-23-2011, 04:08 PM
Rkeytek's Avatar
Rkeytek Rkeytek is offline
Vehicle: 2011 ram 1500
Rep:210
Rkeytek has a spectacular aura aboutRkeytek has a spectacular aura aboutRkeytek has a spectacular aura about
Before peeling off the masking lightly run an Xacto knife around the edge to "break" the paint...might give you a sharper line as well.
Old 09-23-2011, 04:17 PM
916Timmy's Avatar
Rep:1443
That is what I was going to try this time! Thanks man!
Old 11-25-2011, 12:09 PM
Never Satisfied's Avatar
Never Satisfied Never Satisfied is offline
Vehicle: 2011 Dodge Ram
Color: Deepwater Blue
Rep:29
Never Satisfied is on a distinguished road
Any updates on how you made out with this? I would love to tackle this project too but a little worried...
Old 11-25-2011, 12:53 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
I thought these emblems came apart (ring and ram's head is separate from the black background). If that's the case, take it apart and paint the background separately. That would give better transitions from the chrome to the background anyway.
Old 11-25-2011, 01:25 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Thats only the front the rear is 1 piece
Old 11-28-2011, 06:58 PM
916Timmy's Avatar
Rep:1443
Going to order another badge and try again eventually, but it has been super cold which is bad for paint adhesion!
Painting Grille Emblem Background!!! 916Timmy Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 44 01-19-2012 07:01 PM
touch up painting Excoastie Other Vehicle Discussion 5 04-19-2011 10:36 AM
Painting plastics jwsnowman Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 11 02-23-2011 06:39 PM
Need opinions on my tailgate emblem mod. see pics ewb 2010 Dodge Ram Forum 40 02-07-2011 02:51 PM
4X4 Emblem needed hawk570 2009 Dodge Ram Forum 0 09-10-2009 09:40 PM
