Old 09-20-2011, 09:14 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
no that's fine. higher octane fuel is ok. when running the 91 tune you need to have 91 octane minimum; when running the 93 tune you need to have 93 octane minimum...etc...
Sean
Old 09-20-2011, 10:04 PM
jbeauds89's Avatar
jbeauds89 jbeauds89 is offline
Vehicle: 2005 Dodge Ram hemi
jbeauds89 is on a distinguished road
so i just installed the tuner and after it saved my stock files i was able to pick a tune and i didnt see a 93 tune, just performance 91, tow,87,and mileage xs
Old 09-20-2011, 10:10 PM
snrusnak's Avatar
Rep:1385
Sorry I think 91 is all you have. I have a newer truck I think for the 2nd gen hemi and 2nd gen 4.7L they offer a 93 tune. Don't worry about it, it's basically the same tune. Superchips told me they just add some timing advance for the 93 tune and it adds approx. 3 to 6 hp.....
Sean
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
There is no 93 tune for 3rd gen ram hemis.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 09-20-2011, 10:29 PM
jbeauds89's Avatar
alrighttt so i dont have to run 93 in the performance 91 tune..the truck screams from 0-60 with the cortex n esp. with my side exhaust, it seems like my 1st gear shifts alot hiigher than before
Old 09-20-2011, 10:34 PM
snrusnak's Avatar
Rep:1385
Yeah if you are running the 91 performance tune just make sure you have a full tank of at least 91 or higher octane fuel. You should be able to adjust shift points for each gear. I recommend that if you raise the shift pionts, don't max them out, but raise them all by the same amount....for example: if you raise 1st to 2nd shift by 200 rpm, then only raise 2nd to 3rd by 200 rpm.....etc...
All values should be safe as they "don't give you enough chain to choke yourself"....or in other words they don't give you enough adjustment to really cause issues. That said, if you redline every time you accelerate you will obviously wear out the engine quicker lol.
Also, when you adjust the torque management, I recommend not completely removing it. Leave it on at least like 5% or so.
Enjoy! SC really wakes up the truck!
Sean
Old 09-20-2011, 10:42 PM
ORT's Avatar
ORT ORT is offline
Rep:184
It was found during beta testing of the advance trans options that a tm of between 5 and 8 percent gives the best results.
Old 09-20-2011, 10:43 PM
jbeauds89's Avatar
i havent touched the shift points yet thats why im confused why the 1st gear seems so much longer than before...im new to the truck n superchip scene
Old 09-20-2011, 10:44 PM
snrusnak's Avatar
Rep:1385
^ there's the backup data ^
lol
Sean
Old 09-20-2011, 10:45 PM
snrusnak's Avatar
Rep:1385
It probably (shouldn't be) any higher of a shift point if you didn't adjust it. What may be happening is it is revving a little faster, and it shifts hard into gear(since the torque management doesn't cut throttle now) and it allows the rpms to rise slightly when shifting...
Sean
WTS- cortex superchip Ram420 Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 20 09-29-2011 02:28 PM
Diablo vs. Superchip Pwhite Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 5 12-23-2010 09:49 PM
Superchips Cortex or Flashpaq for my 03 4,7? ThomasRam Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 11 05-12-2010 04:47 PM
Cortex Superchip TexasTechRam Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 11 05-11-2010 09:28 PM
Flashpaq, Cortex, Predator cmlrc Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 10 02-18-2010 10:01 PM
