Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2011 Dodge Ram Forum
Old 10-17-2011, 07:02 PM
old amateur's Avatar
old amateur old amateur is offline
Vehicle: 2011 Ram 1500 Crew
Color: red
old amateur is on a distinguished road
Just out playing with mine. The manual suggests activating the Neutral button prior to engaging 4H or 4L. I got it to work in both however by putting the transmission in Neutral however the Neutral button doesn't light up when pushed. Is it supposed to? 4L definately engaged when turning too.
Old 10-17-2011, 07:27 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Activating the neutral button ?????
I think they refereed to placing the 'transmission' in neutral while shifting into 4LO. There is a 'procedure' for placing the T-case in neutral....and unless you are planning on towing the Ram behind an RV or something, you don't want this mode.
They make mention NOT to pause in the neutral position, as this may require shutting the engine off to complete the T-case shift....but this only applies to manual shift T-cases, not the electronic shift ones.
brad
Interested in one of my mods?
Old 10-18-2011, 12:41 AM
Maintenancedept Maintenancedept is offline
Vehicle: 11 3500 4X4 CrewCab Non-dually
Maintenancedept is on a distinguished road
My '11 3500 diesel crew cab is strictly business in 4-low. If I turn sharp in gravel while moving slow, the front will surge the steering wheel, while the inside rear will "peel out" every three feet or so. I have assumed both axles "lock" while in 4-low. For that reason I never run 4-by on bare pavement.
Old 10-18-2011, 12:58 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
I suppose its totally possible there was change in 11' models,
but I have never heard or read anything on it.
All I know is in 4WD Auto (awd) my 10' is invisible on pavement sharp turning,
It studders in 4hi lock or 4lo lock and the front tire will bind and chirp at full steering lock.
post up if you find more info on a change in the new models
^^^^ Mine behaves exactly the same way.
Old 10-18-2011, 07:48 AM
Color: red
Thanks Brad. Makes sense to have the T-case in neutral when towing. Confusing when the instructions refer to using neutral and then have a button labelled neutral under the drive select knob.
If you have one, is it supposed to light up when activated? Mine does not.
cheers,
Old 10-18-2011, 10:10 AM
brad12kx's Avatar
Rep:2581
It only lights up when actually in neutral. The proceedure to place the T-case into neutral is -
Shift T-case to anything but 4WDauto
Turn engine off
Turn Key to the Run position (Do NOT Start)
Press and hold brake pedal
Place transmission in neutral
Press and hold the Neutral Button until the neutral light stays on solid (few seconds)
You can now place transmission in park and remove the key
(NOTE - Park will no longer stop your truck from rolling! Be Very Careful and use the park brake!)
To get it out of neutral, do the same procedure + park brake applied, but this time press the Neutral Button until the light goes out (not flashing)
For detailed information on this, look in your owners manual under 'Recreational Towing'.
brad
Old 10-18-2011, 12:12 PM
Color: red
So, don't try this on a hill facing the creek? Think I'll just leave it alone.
cheers,
Old 10-18-2011, 03:29 PM
Green 1500's Avatar
Green 1500 Green 1500 is offline
Vehicle: 2011 Dodge Ram 1500 QC
Color: Hunter Green
Rep:17
Green 1500 is on a distinguished road
I was reading that you can switch into 4wd auto and 4 high while you are driving up to 55 mph. So you do not have to stop to put it in 4wd hi.
Old 10-18-2011, 07:23 PM
Color: red
That's my understanding though your mph may be a little high. This is the first dash mounted switch thing to change into 4 wheel drive I have had. The others were all manual.
Old 10-18-2011, 08:49 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I believe it is 55. I'm pretty sure you could do that with some of the manual t cases in third gens. I'm no engineer(yet) but im still a fan of being at a complete stop with the truck out of gear
Bumper Swap Question AKRAM Body & Interior 3 05-24-2011 11:10 AM
Cam Question dodgeguy123 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 4 01-19-2011 03:05 AM
Oil Monitor Reset Question Mr. Ed Cummins Diesel Specific Topics 4 10-03-2010 07:20 PM
Help me I have a question?????? white03ram1500 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 12-02-2009 07:54 PM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 09:31 PM
