Old 10-19-2011, 03:52 PM
Green 1500's Avatar
Green 1500 Green 1500 is offline
Vehicle: 2011 Dodge Ram 1500 QC
Color: Hunter Green
Rep:17
Green 1500 is on a distinguished road
from the owners manual:
2H ⇔ 4H
Shifting between 2H and 4H can be made with the
vehicle stopped or in motion. If the vehicle is in motion,
shifts can be made up to 55 mph (88 km/h). With the
vehicle in motion, the transfer case will engage/
disengage faster if you momentarily release the accelerator
pedal after completing the shift. Apply a constant
force when shifting the transfer case lever.
Old 10-20-2011, 01:59 PM
herc herc is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
herc is on a distinguished road
So far, we haven't heard from anyone that has witnessed what would be expected (chatter, chirp, shake) in 4H or 4L on a 2011 with the active transfer case. I'm tempted to try it myself, but don't really have any access to dirt nearby, and well... I'm sitting in my office and the truck's outside...
Its amazing how difficult it is to find information on how this stuff actually works, but I haven't seen anything to indicate that a new front diff was used on the 2011's. Like others said, the front diff is open, meaning their aren't any clutches in there, and my initial conclusion is that the dealer is either just making crap up, or just doesn't understand. I might be wrong, but even the stability control system uses brake pressure, and doesn't do its thing by talking to some fancy intelligent differential. If you google DTCS or "Drive train control system", you pretty much get to this thread, so either the term is incorrect, or the dealer is just trying to sound intelligent about something he doesn't know anything about.
I HAVE seen some reviews that talked about using Chrysler's "new active transfer case" in the 2011s, but nothing official. They also talk about the "Front-axle Disconnect", but don't explain exactly how it works. Even if it IS a different case than the 2010's used, I would expect it to still work basically the same way. When in 4H or 4L, (not "AUTO"), that coupler should be completely locked up. If it's locked, and the rear drive shaft is turning, then the front one is turning as well, so at least one of the front wheels would have to turn.
Like BRH suggested, I would suspect that the coupler in the transfer case is never actually locking up. It's also possible that the "Front-axle Disconnect" is actually interceding when the wheels are turned to full lock in either direction, but that could cause you grief if you get stuck somewhere and need to be turned sharp to get out.
I'm really hoping that the OP's issue is a problem that can be fixed and not a new "feature".
Old 10-20-2011, 03:29 PM
shujat shujat is offline
Trim Level: Sport 4X4
Color: Mineral Gray
Rep:19
shujat is on a distinguished road
+1 BlackRamHemi for the information!
Old 10-20-2011, 03:41 PM
Ok, a little more research into the DTCM (Drive Train Control Module). Talks about clutches and torque transfers, so this DOES line up with the OP's dealer comments. That is, IF this was just an AWD system like in a Charger or 300. For the trucks, it should ONLY apply when you're in "4AUTO" mode.
Old 01-17-2012, 02:43 PM
llsht14's Avatar
llsht14 llsht14 is offline
Vehicle: 2011 Ram 2500 Megacab Cummins
Rep:25
llsht14 is on a distinguished road
im having the same issue with my lifted 2011 ram, dodge says its fine, but i know its not
2011 Ram 2500 Laramie Megacab Cummins, afe intake, h&s egr delete, flo pro 5" turbo back exhaust, 6 in tip, mini maxx tuner
Sold--- 2011 Ram 1500 Sport
Old 01-20-2012, 10:51 AM
llsht14's Avatar
Rep:25
well after extensive testing, i figured out the problem with my 2011 dodge ram 1500 with the 4AUTO option on the 4wd selector. This transfer case is an active transfer case so according to the dealer it actually senses wheel speed and all that mumbo jumbo and knows when to kick the front end in, with my 37" tires it was throwing this all off, the truck wasn't seeing the needed revolutions for the front to engage, i threw stock tires back on and boom it works flawlessly, now the problem is there isnt a programmer out for the 11's yet. Although i just ordered a hyper tech speedo calibrator and had it overnight ed. Hopefully this will change the revs per mile in my trucks computer so that it can compensate for the larger tires.
Old 01-20-2012, 12:26 PM
diligent1's Avatar
diligent1 diligent1 is offline
Vehicle: 2011 RAM 1500 QC 4x4
diligent1 is on a distinguished road
Yes, but what about 4WD LOCK? This thread is about 4WD LOCK not locking up. AUTO is supposed to do what you just described (and yeah maybe your 37's screwed with it).
But I'm curious if 4WD LOCK is a true LOCK or some wishy washy electronic controlled crap..
Old 01-20-2012, 01:01 PM
llsht14's Avatar
Rep:25
i might have been a little vague, i meant to say that it is happening in the trucks with the 4auto option but when in 4wd lock, its just the way the case works and having the bigger tires screws it all up haha
Old 01-23-2012, 03:30 PM
llsht14's Avatar
Rep:25
Well for anyone who has there truck lifted and also has the 4auto option on there 4wd, I was having issues with mine not engaging the front end correctly, almost laggy kind of, i ended up getting a hyper tech speedo calibrator and boom problem completely gone, apparently out active transfer cases monitor wheel slip and speed, and that was all getting thrown off with the larger tires, i use the calibrator, drove it outside and it never skipped a beat. im really glad that it worked to because if not i was kinda screwed as far as the 4wd working properly
Old 02-08-2012, 08:13 PM
Two2crazy's Avatar
Two2crazy Two2crazy is offline
Vehicle: 2011
Trim Level: Big horn
Color: Hunter green
Two2crazy is on a distinguished road
ok so its gonna snow lightly tonight and my wife has told me she is going to take my truck tomorrow .......does she just put it 4auto and go through her day or what do i tellher to do i havent driven it the snow yet myself with only 1-2 in coming i would think you dont even need it but she is excited to try it out so 4auto or 4hi and she i set it up for her tonight or can she do it
Bumper Swap Question AKRAM Body & Interior 3 05-24-2011 11:10 AM
Cam Question dodgeguy123 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 4 01-19-2011 02:05 AM
Oil Monitor Reset Question Mr. Ed Cummins Diesel Specific Topics 4 10-03-2010 07:20 PM
Help me I have a question?????? white03ram1500 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 12-02-2009 06:54 PM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 08:31 PM
