Air Intake - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 09-21-2011, 11:47 PM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
thats sweet, you think we could see some pics underneath the hhood??
I'll give you ALL of it
update:
I finally got around to installing my Fastman TB,
..and to direct a little extra air to my Airaid I fab'd up a Ram Air feed from the front bumper:
(after I removed the ugly fake plastic grill from my Sports lower bumper, looks better without it anyway)
Stock vs Fastman...
Flex Tube from the hardware store can extend from 9" to 21"
I bought two with a coupler to join them but only needed one.
Held in place with a couple small bungee cords, 5 minute job
Wow what a difference! My Airaid box takes air from the same fender opening as the stock box, and it always seemd a bit limited to me.
Old 09-21-2011, 11:51 PM
Rep:561
oops double post
Old 09-22-2011, 12:01 AM
Rep:561
Stock fender opening for CAI is somewhat restricted by the frame and headlight bucket/support
Here's the view from the engine bay with the stock air box removed, and what it looks like from the front with the headlight removed:
This is the natural air path (red line) that all aftermarket CAI (including the stock box) currently use, the green oval marks the approximate direction of top of my flex tube.
Ramming extra air from the Front instead of letting it suck air from below in combo with the Airaid and FastMan feels like a new Beast!
The Airaid, although great due to the shear size of the filter element, is still limited because it still relies on the limited size of the stock fender opening, same as stock.
The reason many people say aftermarket CAI's are not much better than stock (just louder) is because they all share the same limitation...
Airaid, K&N, aFe, AEM and Mopar CAI all share that same small fender opening, lowest common denominator = weak (as well as being open on top)
...at least the stock box with a drop in high flow flat filter is still sealed.
Redirecting air from my front bumper certainly helped force more air toward that opening, but only a single tube used and
my flex tube does not go all the way up...only about 8" up and about 8" short. It doesn't make an actual connection to the box.
Before and after comparison:
The Airaid does not have an additional port at the bottom of the box, and although I considered cutting one in,
the Volant caught my eye since it already has one...and a sealed top ...which I like for the car wash.
Just looking at both systems side by side, you tell the alignment of the tube,
the taller smooth arc of the tube and the positioning/direction of the box in relation to the fender opening that the Volant is a better design.
The powercore filter also takes in air from the end that's pointed directly at the air source.
Now look at the Airaid and follow the number of 90º turns and twists the air has to make just to get to the throttle body from the bumper (about 5-6)
The Volants Powercore filter, designed and manufactured by Donaldson is well known for high flow Diesel applications.
This material is a high-quality synthetic, that won't deteriorate as easily as traditional paper element and cotton/gauze filter media, while also providing vastly improved filtration up to 99.97%. In addition, it's water resistant and never needs oiling. PowerCore® Filtration Technology works by directing air into the front of the filter, where it is channeled into its fluted design. The channels are alternately sealed, allowing air to enter through an open flute and forcing it to exit out an adjacent flute. This allows the air to be filtered in one pass through the filter media with less restriction, allowing clean air to enter your engine for increased airflow and higher filtration efficiency. This technology allows the filter to include a 4 year or 100,000 miles warranty when used in urban conditions.
(edit got the order of my posts mixed up)
Old 09-22-2011, 12:02 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
man thats awesome...did you have to make a hole in the bottom of the box and fender port to connect the tubing to the actual intake box?
-Pat-
Old 09-22-2011, 12:15 AM
Rep:561
from a previous post:
Well now that my Volant is in I have another update...
1st of all, It Looks 10 times better than any other CAI, (IMHO)
and I like that I can pressure wash the engine bay without being concerned about getting the filter element wet.
The tube as a nice smooth arc to it, and the box is positioned toward the fender port instead of 90º like the Airaid.
The powercore filter takes in air from the end, not the sides so its a more direct path to the throttle body now.
install was pretty simple, only about 10 minutes (no engine cover and re-used the Airaid's breather tube)
Pipe insulation installed and pinched to close the slight gap at the fender:
Not being the patient type, I wasn't satisfied to wait for Volants release of their lower scoop in November
...besides our Track closes after the first week in Oct.
So now I have Dual 3" feeder tubes to my air box, one to the stock fender port,
and one directly to the bottom of the Volant box, But BOTH force fed and Ram'd from the front bumper opening.
I know a smooth tube would be better than the ribbed flex tube,
but for now this works and I'm out less than $20 total until the scoop is available.
View from the Bottom looking up (Left tube goes to the air box, Right goes up the fender)
View from below where the tube enters the lower port on the Volant box.
My Butt Dyno tells me this is the Best CAI setup you can do on a 4G Ram.
Official track slips will be available at the end of the month.
that about covers my findings for now until I get back to the track for some actual track slips
Old 09-22-2011, 12:21 AM
Rep:561
the Volant comes with a lower port in the box already, one reason I switched.
Volant will be releasing a lower scoop in November for the 4G Hemi to connect to their box
( I just didn't feel like waiting that long and made my own for now)
They already make dozens of scoops for other makes/models
Here's what the HD Silverado looks like:
List of Scoops here: http://www.volant.com/scoops.asp
Old 09-22-2011, 12:56 AM
BlackHemI's Avatar
Rep:296
thinking of getting me a volant now...
-Pat-
Old 09-22-2011, 01:57 AM
ram71351's Avatar
ram71351 ram71351 is offline
Vehicle: 2014 Dodge Ram Laramie
Color: Black Gold Pearl
Rep:45
ram71351 is on a distinguished road
That's what I'm leaning towards also. Just waiting on some testing from BRH though.
Old 09-22-2011, 08:13 AM
stangd1909's Avatar
stangd1909 stangd1909 is offline
Vehicle: 2011 Dodge Ram
Color: Grey
Rep:27
stangd1909 is on a distinguished road
Very cool.............
Old 09-22-2011, 08:16 AM
stangd1909's Avatar
Color: Grey
Rep:27
On the Volant, the top part that srcew on to the top of box, is it a screen......or is it solid?
Kegger MOD DIY wermbang Dodge Ram Knowledge Base 8 09-09-2012 02:05 PM
Cold Air Intake & Ram Air Hood? Stonednloaded Body & Interior 1 05-06-2011 02:12 PM
Closed air box cold air intake? wickedpissahtruck 2010 Dodge Ram Forum 1 05-05-2011 10:26 PM
Keggar Mod wermbang Dodge Ram Knowledge Base 1 04-05-2011 02:16 AM
