Old 09-22-2011, 08:52 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Originally Posted by stangd1909 View Post
On the Volant, the top part that srcew on to the top of box, is it a screen......or is it solid?
It's solid, with a rubber seal around the perimeter.
Features
Volant Air Filter Box: Our Cross-Link polyethylene box is engineered to each specific application for low restriction and an increase in air volume. It insulates and protects the filter from engine heat, moisture, dust and debris to provide colder air to the engine for an increase in horsepower.
Volant Air Duct: Factory air inlet ducts use sound baffles and awkward bends which restrict flow. Our Cross-Link polyethylene air ducts are sculptured to give the engine less restrictive breathing. Incorporating larger diameters and unique bends, that can't be duplicated with metal ducts, allow for maximum airflow velocity and throttle response.
NEW Volant Filters with PowerCore® Filtration Technology: This air filter is the most revolutionary on the market. Manufactured by Donaldson® to Volant's applications, this filter uses advanced technology for improved efficiency. This material is a high-quality synthetic, that won't deteriorate as easily as traditional paper element and cotton/gauze filter media, while also providing vastly improved filtration up to 99.97%. In addition, it's water resistant and never needs oiling. PowerCore® Filtration Technology works by directing air into the front of the filter, where it is channeled into its fluted design. The channels are alternately sealed, allowing air to enter through an open flute and forcing it to exit out an adjacent flute. This allows the air to be filtered in one pass through the filter media with less restriction, allowing clean air to enter your engine for increased airflow and higher filtration efficiency. This technology allows the filter to include a 4 year or 100,000 miles warranty when used in urban conditions.
Volant offers Polished Aluminum or Carbon Fiber Look lids. (Some of our older applications and low production intake kits have the carbon fiber look lid.)
Polished Aluminum Lid: Available on all Volant's popular intake systems, this embossed and polished lid features a high-grade neoprene foam backing for good sound insulation that enhances your engine compartment.
High Performance Silicon Connectors: Our silicone hose connectors provide flexibility while maintaining strength and thermal stability. They won't crack or deform over time like rubber connectors.
Stainless Steel Clamps: We only use marine-grade, stainless steel clamps that provide optimal performance to provide a solid seal that won't loosen or deteriorate.
PowerCore® is a registered tradename of Donaldson Company Inc.
CAI Intake Filters Exhaust Systems Scoops PowerCore
Product link for more info: http://volant.com/edetail.asp?ID=632
Old 09-22-2011, 08:56 AM
THAT911GUY's Avatar
THAT911GUY THAT911GUY is offline
Vehicle: 2011 Dodge Ram 1500
Rep:32
THAT911GUY is on a distinguished road
Took a few, but finally found one for our year models. The only one I have found so far is for 09-10. Were there any changes that would affect my 2011 model as far as the engine bay is concerned?
Old 09-22-2011, 09:03 AM
stangd1909's Avatar
stangd1909 stangd1909 is offline
Color: Grey
Rep:27
stangd1909 is on a distinguished road
Features
Thanks a lot!
Kegger MOD DIY wermbang Dodge Ram Knowledge Base 8 09-09-2012 02:05 PM
Cold Air Intake & Ram Air Hood? Stonednloaded Body & Interior 1 05-06-2011 02:12 PM
Closed air box cold air intake? wickedpissahtruck 2010 Dodge Ram Forum 1 05-05-2011 10:26 PM
Keggar Mod wermbang Dodge Ram Knowledge Base 1 04-05-2011 02:16 AM
