Old 09-20-2011, 09:44 PM
dusted72's Avatar
dusted72 dusted72 is offline
Vehicle: 1998 Dodge Ram
Trim Level: SS/T
dusted72 is on a distinguished road
Default Strange vaccum leak rough idle?
Ok so I bought a 98 Ram SS/T last Wednesday. It runs great now since I did a tune up but the question is regarding a strange vaccum leak. It happens after I start it for the first time and let it idle. After about 5 minutes it develops what sounds like a vaccum leak then it idles like it has a nice cam in it. After about 5 minutes of that the vaccum leak stops and it idles smooth as silk. Also when I drive I can hear a vaccum leak but it runs really good so I don't know where to start looking.
Explosions are cool.
Old 09-21-2011, 02:20 AM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
I am having a simular issue with my 97... I am hearing impaired so I dont know if theres any leak sounds yet till I get my wife or someone to listen for me. If I find out anything this weekend I will definately post it.
Mike
Old 09-21-2011, 10:44 AM
dusted72's Avatar
Trim Level: SS/T
Well I am gonna be actively trying to find it this week if I do find something I will let you know.
Old 09-21-2011, 04:58 PM
sonocativo's Avatar
Rep:210
I heard on other forums to spray carb cleaner/starting fluid on the vacumm lines and intake gasket area and so, if the idle races you found the leak. This is also a very dangerous fire hazzard if not careful. I have done it before on race cars I had as a quick find method but pulling and checking hoses is time consuming as well. I am wondering about my plenum pan as well since I am using oil somewhere but the truck doesnt smoke or leak so probly burning it at high rpms on the highway????
Mike
Old 09-21-2011, 05:14 PM
dusted72's Avatar
Trim Level: SS/T
Could be the plunum too, but I haven't owned mine long enough to know if it using oil or not. I did do an oil change last week and only drained half of what I put in it. So oil is going somewhere and it doesn't leak so I think I may be doing a plenum repair when I get back as well. But today I noticed that when the vaccum leak starts while driving the A/C stops blowing cold. Anybody else have that problem? Then the vaccum leak stops and the A/C kicks back on.
Old 09-21-2011, 10:12 PM
sonocativo's Avatar
Rep:210
Hmmm, I seen some threads on here where after 5 minutes the ac quits on them.... so maybe its a related issue? It would take me forever to find those threads again????
Mike
Old 09-30-2011, 10:32 AM
steadian steadian is offline
Vehicle: 2001 Dodge Ram 2500
Trim Level: Plain
steadian is on a distinguished road
This is exactly what is happening to my 2001 ram 2500. The rough idle, air conditioning blowing hot air, everything. Does anyone have a solution? it would be greatly appreciated
Old 10-03-2011, 12:36 PM
doug123 doug123 is offline
Vehicle: 1995 ram
doug123 is on a distinguished road
I've had a similar problem with the vacuum leak, rough idle, possible iac motor on the throttle body. changed mine seemed to do the trick. not sure about the a/c issue.
Old 10-03-2011, 02:28 PM
sonocativo's Avatar
Rep:210
I had a cracked PVC valve, after replacing it, still has the crazy idle. Ended up working on the door and replacing the battery hold down so didnt get anything done with the idling yet...Gonna try this week if i get a bit of free time.
Mike
Rough Idle, Bad mileage, EGR valve? madmax0r 5.9L V8 Specific Topics 11 01-29-2012 10:08 PM
Low idle, rough idle problem and more starquestbd22 4.7L PowerTech V8 Specific Topics 9 01-17-2012 04:03 AM
need help, very rough cold start idle Apathy13 5.9L V8 Specific Topics 4 01-04-2011 12:31 AM
Rough Idle when first started 2002Sport 5.9L V8 Specific Topics 16 07-21-2010 03:01 PM
New 2010 Hemi Rough Idle jimw 5.7L (345 cu in) HEMI V8 Specific Topics 3 06-20-2010 02:07 PM
