Old 09-20-2011, 09:26 PM
RTBenny RTBenny is offline
Vehicle: 2012 Ram R/T
RTBenny is on a distinguished road
Default Going to the dyno but thought of a problem.
Hey guys, going to the dyno Thursday but I thought of a potential problem. Since my truck is governed to 105 mph, how will I rev it all the way out in fourth gear? By the way, I'm stone stock and my buddy is taking his 07 Titan. It has a Nismo intake, offroad B pipes, Magnaflow exhaust and a Superchips tuner running a 93 octane tune and 3 degree timing advance. It ran a 14.9 at 91 mph. It's a 4x4 extended cab. Anyone want to throw some guesses on what the trucks will make?
Also I understand that this may not be the best location for this thread but this section seems to have a lot more traffic than the others. I just need an answer rather quickly and honestly, there are so many different sections that it gets confusing.
2013 F-150 King Ranch 4wd 5.0
Old 09-20-2011, 09:51 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Rpm not speed
Your hp curve will be pretty flat from 3500 rpm to 44-4500 rpm With your peak tq number closer to 5500 rpm
Your probably going to see 325 hp and 335ft-lbs plus or minus depending on gears, mods, and weather
Old 09-20-2011, 10:06 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:605
Dyno results i have seen are mostly 2nd and 3rd gear runs. Lot of folks run it to the top of 3rd which will go to the limiter.
Old 09-20-2011, 10:11 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
I call BS on the 325 hp and 335ft-lbs...
It's a Ram with a Hemi... got to be at least eleventy billion horsepower with infinity times two on the torque.
Old 09-20-2011, 10:18 PM
Don't run it in 4th...keep it in 3rd.
Old 09-21-2011, 12:59 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Find out which gear is 1:1 or closest to 1:1.
that take the torque multiplaction from the transmissio gear rations out of the equation as much as possible.
What type of dyno are you going on?
2011 Big Horn 4x4 -SnowWhite-
Old 09-21-2011, 06:41 AM
It's a Dynojet. I know you're supposed to use the gear with a 1:1 ratio which is fourth in my truck (third if I let it shift itself). But that gear will go to almost 130 mph. Since my speedo will be climbing (it does when I'm spinning so I assume it will on the dyno) won't it cut off at 105 mph just like on the interstate? Now, I know I can run it a gear low but how much will that affect the numbers?
Old 09-21-2011, 08:26 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
That's pretty quick for a nissan titan....I'll say 295 rwhp peak for him and 310 rwhp peak for you...that still may be too optimistic...
I believe the 2012 has the "6 speed" right? So yes your 4th gear would be 1:1. You should really be able to run in any gear and they can take that gear ratio and compensate for it. Your 3rd gear ratio would be 1.5:1
Sean
Old 09-21-2011, 05:26 PM
Haha, I hope I beat him. It is quick though, it simply ran away from my 07 Hemi. It was a quad cab 4x4 but it was no comparison. The Titan definitely delivers more than expected.
Yeah, I'll run it in third and tell the guy what the ratio is and hopefully he can correct it. My buddy is going to run the Titan in 3rd once too (1.52:1) just to make sure we have comparable numbers. Thanks for the help.
Old 09-21-2011, 06:40 PM
SS4Luck's Avatar
Rep:310
Let us know how it goes.
Wax that import for us domestics!
Problem with trailer brake controller on diesel 3500 1newtododge Electrical 2 08-26-2011 10:45 AM
Help diagnose my tranny problem albow Dodge Ram General Discussion 2 06-28-2011 01:35 PM
The Persisting HID Problem.... Valldar Custom Dodge Ram Interior and Exterior Lighting 2 08-02-2010 03:45 PM
Ingnition problem 808state V10 Specific Topics 4 10-31-2009 10:36 PM
Yet another HID problem griffin407c Custom Dodge Ram Interior and Exterior Lighting 10 10-27-2009 04:37 PM
