Old 09-21-2011, 08:06 PM
Rep:2705
compare yours to this, 3:55 ratio, 545RFE transmission
[IMG]
missed shift or something
[IMG]
Old 09-21-2011, 08:51 PM
RTBenny RTBenny is offline
Vehicle: 2012 Ram R/T
RTBenny is on a distinguished road
Nice numbers and the curve looks good. I'm going to try to start my pull a little lower, mayber 3200-3300. Hopefully it won't try to downshift. I'd be stoked with 315whp but mine will probably be a little lower due to lower gears and looser converter. Thanks for the post, will still be good for comparisons.
2013 F-150 King Ranch 4wd 5.0
Old 09-21-2011, 09:10 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I think they take into account gear ratios....but I'm not sure about that....
I thought yours might dyno lower than others due to the converter...I bet that converter is less efficient, even though it stalls higher and allows you to run a quicker 1/4 mile...typically when they make a "loose" converter from a factory one they are not as efficient.
Sean
Old 09-21-2011, 09:22 PM
Yeah, I'm not sure on the whole converter thing. I've never had a sproty vehicle that was auto before this one. And I as far as the dyno correcting for gearing, I've been told both ways. I hope they do but I'm not sure.
Old 09-21-2011, 09:32 PM
snrusnak's Avatar
Rep:1385
yeah I honestly don't know either....I've been told so many different things it's not even funny....but I THINK that it depends on the type of dyno, and some can correct and some can't (it has to do with how the dyno measures the torque.....)
What I get out of all of it is the operator of the dyno is what matters....
I've seen lingenfelter vettes dyno at like 400 hp lol and I think they are closer to 1000 hp...
I've also been told dyno's are basically only good for tracking changes on a particular vehicle...
Sean
Old 09-21-2011, 09:36 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
The 1.00:1 gear is the real 3rd, or 4th in manual shift mode! You will hit the limiter if you run it in that gear!
Old 09-21-2011, 09:40 PM
snrusnak's Avatar
Rep:1385
He has a 2012, I think it has the 65rfe not the 545rfe, so his 3rd gear is same as our 2nd prime, 1.5:1
Sean
Old 09-21-2011, 09:46 PM
Rep:2705
I wasn't in my Ram, the technician was
In fact i didn't go into the shop when the run was being done, i was standing at the side door of the building
Watching the straps struggling to hold the Ram down
I got a kick how the Ram squatted & then lifted up at each shift point
http://www.thedynoshop.com/photos/
Old 09-22-2011, 07:10 AM
Well we'll know for sure tonight. I'll make a new thread with all the runs of my truck and my buddy's Titan. Either way, I'll have a good baseline that I can compare to later on.
Old 09-22-2011, 10:39 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
My aftermarket Torque Convert (Edge 3000 stall), made little/no difference at all on the Dyno.
I think it's one of those mods that only shows up on a track time slip.
where I drop 2-3 tenths over my stock stall runs.
Our Dyno runs are done by our local CMR Tuner, who always runs Diablo Tuned Hemi's in 4th gear.
He said it's the best way to get a good read for a base line before he tunes them.
A third gear pull, although it reads higher at 1:1, makes for a much shorter run and often the truck tries to kick down into 2nd prime throwing numbers off even further.
x2
Yes, that's the Key right there
Here's my baseline run Run with my higher stall TC compared to my buds QC with stock 2300 stall converter...
Both trucks with similar intake/exhaust/Diablo TrinityTuner
Both are 10' Hemi 4x4's with 3.55 gears. RC vs QC
Mine: Airiad intake Fastman TB, Magnaflow CatBack, stock 20's w Heavier Terra Grapplers
His: K&N drop-in, Magnaflow Mufflex 14", stock 20's w G/Y tires
My HP 309.03 / TQ 347.52
(slight stumble at the start trying to paddle the throttle to avoid downshifting)
Friends QC
HP 303.97 / TQ 348.17
Here's his run on YouTube ...
Problem with trailer brake controller on diesel 3500 1newtododge Electrical 2 08-26-2011 11:45 AM
Help diagnose my tranny problem albow Dodge Ram General Discussion 2 06-28-2011 02:35 PM
The Persisting HID Problem.... Valldar Custom Dodge Ram Interior and Exterior Lighting 2 08-02-2010 04:45 PM
Ingnition problem 808state V10 Specific Topics 4 10-31-2009 11:36 PM
Yet another HID problem griffin407c Custom Dodge Ram Interior and Exterior Lighting 10 10-27-2009 05:37 PM
