Old 09-21-2011, 04:25 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Many people experience better fuel mileage and performance with the mds disabled.
I can understand performance, my MDS has cost me a few freeway pulls cuz it didnt deactivate fast enough, but better fuel milage? Im throwing the BS flag on that one. Whenever my MDS kicks on i get over 23ish MPG and so far im averaging 17.7-18.3 (hand calculated) averaged every week.
I will keep my MDS until one of my mods makes me delete it, weather its a cam or blower
2011 Big Horn 4x4 -SnowWhite-
Old 09-21-2011, 04:26 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Well hey I've never used mds so I don't know but I just know what people post. Some people say they get better mpg without it. I'd assume this is city and not hwy driving.
Sean
Old 09-21-2011, 05:05 PM
Rep:2664
I believe some members are confused about a couple things
the Transmission has Nothing to do with the MDS, but it does ALLOW MDS to work
MDS is a ENGINE function of the 1500 models with the 5.7 Hemi
the 5.7 engines in the 2500 & 3500 series do not have ANY MDS
MDS is a function of the engine, MDS is a 4 cylinder engine function, so your are only using 1/2 the engine
the 545RFE & the 65RFE transmissions has gears, the 65rfe uses one of the 2nd gears differently
First gear
Second low gear
Second high gear
third gear
fourth gear
FIFTH gear
Fifth gear with Torque Converter Lockup
( a brief explanation of TCL also known as TCC, written by a transmission technician,
I wanted to briefly mention what the term lock-up means. Lock up is a feature introduced in about 1982 with the advent of the T-700R4 and T-200-C General motors transmissions. Simply put, since a torque converter is a fluid coupler it will always have a certain amount of ‘slip’ built into it. It is unavoidable due to fluid being the main component of the coupling action. This decreases gas mileage by 1-4 miles per gallon, the built in slippage, that is.
To eliminate the problem, an actual clutch disc has been built right into the torque converter. At a certain speed, usually about 45-50 mph a message from a computer sends a forceful ‘charge‘ of automatic transmission fluid to the converter, which applies the clutch plate inside and eliminates the small amount of built in ‘slippage’.
Darn good idea. A lot of updates and improvements have been developed over the years which has just about perfected the design)
When you are in 5th gear with the torque converter locked, basically OVER DRIVE,
a signal is sent to the electronic controller that allows the MDS on the engine to function, but only IF certain conditions are present, like driving on flatter surfaces at a steady rate of speed, MDS kicks out if you climb a hill because your Engine has to work harder, it needs ALL 8 cylinders. The transmission still stays in 5th with the converter locked up, unless it has to shift down & then the converter becomes unlocked & it goes into a more proper gear
I hope that this clears things up just a little bit, i didn't understand it for a long time
Old 09-21-2011, 07:15 PM
WyGuy's Avatar
WyGuy WyGuy is offline
Vehicle: 2012 Dodge Ram
Trim Level: Outdoorsman
WyGuy is on a distinguished road
Agreed, I do not see how staying out of MDS will increase MPG. I certainly see an an increase in MPG with MDS.
Old 09-21-2011, 07:41 PM
brianak brianak is offline
Vehicle: 2011 Dodge Ram 1500
brianak is on a distinguished road
I get 1-2 MPG better disabling ECO during city driving than I do with it enabled. On the highway ECO has been better.
Old 09-21-2011, 08:15 PM
snrusnak's Avatar
Rep:1385
^ see I'm not crazy people do really post that ^ lol
Sean
Old 09-22-2011, 11:25 AM
silverharley silverharley is offline
Trim Level: Lone Star Edition
silverharley is on a distinguished road
Dumb newbie question: How do you disable the MDS?
Old 09-22-2011, 11:26 AM
snrusnak's Avatar
Rep:1385
It can be disabled with a tuner (not available for 2011)....or you can bump it down into manual shift mode where the EVIC will show "5" on the display, and this disables MDS I believe.
Sean
Old 09-22-2011, 06:20 PM
Perfect!!! Thanks for the help!!!
I know at around 47-52mph(the majority of my drive home from work), the MDS will kick on and off. With the Magnaflows, it drives me crazy!!! I wanna turn if off for that reason!!
I make a 250mi highway drive every weekend, and am getting 20.9mpg on those trips. I love seeing the "ECO" light on for those trips. It just gets old on around town driving.
I appreciate your help
Old 09-22-2011, 07:20 PM
bobhorn bobhorn is offline
Vehicle: 2011 ram 1500 2wd express
Trim Level: 1500 express
bobhorn is on a distinguished road
Send a message via AIM to bobhorn
Help! Only 12 mpg!
So this is my first post here, got my new Hemi ram reg cab
short bed Fire Red W/Black Daytona stripes,391 posi
only options 20" wheels .love the truck! Have yet to get
more than 12.5 mpg mixed 50/50 hiway city. No mater
hard driving or Eco mode! Kills me after reading hundreds
of posts from 4 dr 4 wheel drive owners getting 21 Mpgs
please tell me it's gonna get better! Btw only 650 miles on
it! Hoping it will improve! And ask the dealer on 1,000 mile
service to do the computer Flash!
Thanks guys keep up the cool posts!
