Old 09-27-2011, 11:01 AM
blackpearldodge's Avatar
blackpearldodge blackpearldodge is offline
Vehicle: 2015 Crew Cab 1500 Sport 4x4
Rep:19
blackpearldodge is on a distinguished road
I think you're misunderstanding what that means. When it says "5" it doesn't mean you are in 5, it means that's the highest gear it will allow it to shift to. For example, if you bumped it down to where it showed "3", it would shift 1, 2, 3, but would not shift into 4th. They call this ERS(electronic range selection I think). So if you put it to "5" it will shift normally, the only difference is that MDS will be disabled.
EDIT: and no this does not harm anything...
Thanks for your reply. Nope. I understood correct. It's a no-brainer that putting the transmission into 5 doesn't keep it in that gear at all speeds.
I should have rephrased my statement to something like "So it is okay to have the shifter in 5th to disable the ECO feature?"
I drove around with the shifter in 5th... I did not notice a difference in gas economy (and I was driving like a grandpa!) I'll continue to drive for the rest of the week in 5 to see if my mileage improves.
There's likely one advantage of running in 5 and that is the responsiveness of the vehicle, aggressively depressing the gas pedal provides much better pick-up.
Once you have Black you'll never go back! Hmmmm.....well... now that isn't quite true. I went back to WHITE!
Sport Performance Hood, OEM Mud Flaps, Factory Spray-in Bed Liner, CREE MK-R LED Fog Lights
Old 09-27-2011, 11:17 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
If most of your city driving is a speeds below 60kph, you might even try shifting down to '4' on the EVIC. I noticed this improved my city mileage, and further improved the overall responsiveness of the truck, as it never sees an OD gear.
BTW - The numbers on the EVIC don't follow the gear numbers exactly.
1 = 1st
2 = 2nd
3 = 2nd Prime
4 = 3rd (Direct)
5 = 4th (1st OD gear)
When in 'Drive', you also get 5th gear (2nd OD gear), but you have to contend with the MDS as well.
Also, for piece of mind, you can (within reason) run in any manually selected gear, or in tow/haul mode without worry of hurting anything. For the sake of experimentation and to see what it's like, I would run for a while using the tow/haul mode. You will notice that it shifts a little differently, and decelerates harder, and is more responsive. Some find these characteristics annoying when there is no trailer in tow, some find them desirable.
brad
Interested in one of my mods?
Old 09-27-2011, 11:30 AM
Rep:19
Brad:
Thanks for your help.
I'll experiment running in 4th gear (oops... 4 on EVIC).
Old 09-27-2011, 11:31 AM
Rep:19
Brad:
One more thing; nice truck. Really nice colour!
Old 09-27-2011, 11:53 AM
doug713's Avatar
doug713 doug713 is offline
Vehicle: 2011 Dodge Ram
Rep:33
doug713 is on a distinguished road
Very true. I am getting almost 21 mpg @ 75- 80 mph while in 5th (no eco) and 19.6 mph at the same speeds in "D" eco mode. I don't understand it, but oh well. Love the truck
Old 09-27-2011, 11:57 PM
Rep:19
So... I drove home from work this afternoon in 5th (no eco) and noticed my gas mileage improve quite substantially! Instead of getting between 15.6 and 16.5 litres per 100Km, I shot down to 12.1 litres per 100Km (or around 20 mpg)!
I even shifted down to 4 but didn't feel comfortable in that gear. Though I never noticed an RPM drop between 5 and 4.
As for getting 12 litres per 100Km, I used to get that when my truck was new, and I was doing highway driving (but not in 5 on EVIC).
I'm a believer!
Old 09-28-2011, 09:34 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I'm a believer!
Cool! I think dodge should have made MDS only enabled above a certain speed....like say 55mph or so.
Sean
Old 09-28-2011, 11:22 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
I must jsut get lucky. My road home is 65-70 freeway and 55 street and i set the cruise and just go and get great MPG (between 18-23 on EVIC). I bump it down to 5th and it shoots down to like 16 or so.
Stupid truck lol
2011 Big Horn 4x4 -SnowWhite-
Old 09-28-2011, 11:25 AM
snrusnak's Avatar
Rep:1385
^well freeway driving should be better mpg with MDS.
Sean
Old 09-30-2011, 09:46 PM
Dortmunder Dortmunder is offline
Vehicle: 2011 RAM 1500 Sport Quad Cab
Color: Grey
Rep:31
Dortmunder is on a distinguished road
From what I've read the ECO mode does not really have anything to do with MDS.
Seems like a lot of people think that because "ECO" is displayed then the trucks MDS is active, or whatever.
From what I understand it's just there to show you that you're "driving in a fuel economically correct way". You'll notice if it's in ECO mode and you give it just a little bit too much gas, it will drop it, let off a little and it will show again.
Basically as long as you aren't accelerating too fast it will show ECO. Or if your foot is off the gas altogether.
I could be wrong, but that's what I gathered from reading the manual and looking around online
