Old 09-30-2011, 10:15 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^ I believe that's true....but basically if you're on the freeway at normal speeds, and the ECO is on, then MDS is probably on...
Sean
Old 10-01-2011, 01:17 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Originally Posted by blackpearldodge View Post
Brad:
One more thing; nice truck. Really nice colour!
Thank You. I think I'll change to 'your' colour with my next Ram.
Originally Posted by Dortmunder View Post
From what I've read the ECO mode does not really have anything to do with MDS.
Seems like a lot of people think that because "ECO" is displayed then the trucks MDS is active, or whatever.
From what I understand it's just there to show you that you're "driving in a fuel economically correct way". You'll notice if it's in ECO mode and you give it just a little bit too much gas, it will drop it, let off a little and it will show again.
Basically as long as you aren't accelerating too fast it will show ECO. Or if your foot is off the gas altogether.
I could be wrong, but that's what I gathered from reading the manual and looking around online
That is true. ECO does 'NOT' mean MDS. ECO only means that you are satisfying the computer's algorithm for 'Driving in a fuel efficient fashion'.
MDS on the other hand, requires the engine to be operating at very low load. When you drop 1/2 the cylinders, you have less then 1/2 the power, so the remaining cylinders require a lot more fuel to 'carry the load'. Theoretically, the added fuel is less then double that required (per active cylinder) in 8 cyl mode.....theoretically....
If the load on the engine is low enough to enter MDS mode, it has already satisfied ECO mode, so the light is already on.
In a nutshell -
You can have ECO without MDS, but not the other way. Before you can satisfy the MDS requirement, you have to have already satisfied the ECO requirement....it's not as strict.
Prior to getting my tuner (by which I have disabled MDS), I often noticed the ECO light when driving on the highway, but very, very seldom, did it ever go into MDS mode, and when it did, it was very short lived.
For some, MDS has proven to increase fuel mileage....that is not the scenario I witnessed with my truck....with my driving style.
brad
Interested in one of my mods?
Old 10-01-2011, 01:53 AM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
Its hard to say if the fuel mileage difference is because of the MDS or the different gearing.
When you show "5" you are in Overdrive 1 (0.75) Gear and can not access top gear. When you are in auto you can access Overdrive 2 (0.67).
Gene
Old 10-01-2011, 02:46 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Okay, I must apologize to you guys. Ive been doing all my sub 45mph in 5 instead of auto and my mpg has increased slightly. Like maybe 1 full mile, but that's enough. I noticed in MDS the instant mpg "hunts" a little more and in 5 it just stays solid
2011 Big Horn 4x4 -SnowWhite-
Old 10-01-2011, 03:48 AM
BigH0ss's Avatar
BigH0ss BigH0ss is offline
Vehicle: 2013 Ram
Trim Level: Regular Cab 4x4
Color: Maximum Steel
Rep:122
Wow after reading all that I'm even more confused! Lmao. So how do u know ur running 4 cylinders? I am at 16.4 right now on a 20 mile trip half freeway half city. Sound right? Once I get up to speed "eco" comes on and then I drive in a manor to keep it on lol sometimes it feels like it bogs if I give it a little gas.
Old 10-01-2011, 09:33 AM
Dortmunder Dortmunder is offline
Vehicle: 2011 RAM 1500 Sport Quad Cab
Color: Grey
Rep:31
Dortmunder is on a distinguished road
I've found no way to tell if MDS is on.
People have said they can feel it when it drops into MDS, but I've never felt that.
Then again I haven't really done any long driving in my truck yet, almost all to/from work, which is only about 10-15 km in the city.
I would assume it only activates at a certain speed and after it has been steady for a set amount of time. Basically highway driving.
Old 10-01-2011, 11:50 AM
brad12kx's Avatar
Rep:2581
I always notice when MDS kicks in, but I've owned so many questionable vehicles in my past, that I have grown very sensitive to the 'feel' of the vehicle when I'm driving. It is not something that is 'in your face' noticeable.....but rather very subtle. I have also noticed it most often in city driving, as for the most part little engine power is required after you have reached cruising speed so the conditions are idea for MDS operation.
When in MDS mode, a slight increase in throttle will usually feel like a mild shutter, and a heavy press of the throttle will be followed by a noticeable lag or bog as it changes from MDS mode back to 8 cyl mode. Once you tune your senses to feel it, it is very distinctive.
brad
Old 10-01-2011, 01:59 PM
Color: Grey
Rep:31
Ah, yeah I've felt something like that. But only after I had my CAI put on. I thought it might just be the engine getting used to it or whatever. I heard about unplugging the negative battery connector, but thought that might wipe the EVIC so didn't bother
Old 10-01-2011, 06:17 PM
Second Life's Avatar
Second Life Second Life is offline
Vehicle: 2011 Ram 1500 Crewcab
Trim Level: Outdoorsman 4x4
Color: Deep cherry red
Second Life is on a distinguished road
If ECO and MDS isn't the same thing... How come when you're on ERS you will never see the ECO light up?
Truxedo LoPro - Westin Premier 6'' Oval tubes - Sonnax line pressure booster - Dee Zee rubber bed mat - Magnaflow 12259 - K&N Aircharger - Bilstein 5100 set at 2.8'' - BullyDog GT for Hemi Plus
Old 10-01-2011, 10:02 PM
brad12kx's Avatar
Rep:2581
The same holds true in Tow/Haul. The algorithm does not consider Tow/Haul or ERS mod as an acceptable criteria. IMO, that's a programming booboo. Not everyone is using ERS in a non-economical fashion, and Tow/Haul does not mean Guzzle and Waste. It also appears that the MDS mode uses the existence of the ECO light as part of it's criteria. I call this 'lazy programming'. Why write truly valid code if you can simply test for the existence of something else that you 'believe' is an acceptable criteria source.
The good side - if you don't have a programmer, at least you have a couple of different ways of turning the MDS off.
brad
