igniton key sticking in ignition - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 4.7L (287 cu in) PowerTech V8 Specific Topics
Old 09-21-2011, 05:39 PM
daggertats daggertats is offline
Vehicle: 2011 ram reg cab 4x4
Trim Level: st
Color: deep water blue pearl coat
Rep:14
daggertats is on a distinguished road
Default igniton key sticking in ignition
i have a 2011 ram st reg cab. manual door locks. it has about 500 miles on it and is about 3 weeks old. i noticed on 2 or 3 occasions that the ignition key seems to stick in the igniton when i try and remove it. its all the way off and i cant turn it anymore. i was thinking about a few drops of liquid graphite however the ignition is something i never seen before and before i use the graphite i wanna be sure i dont mess anything up. maybe just a few drops on the key and then stick the key in instead of putting it directly into the igniton itself? any help is appreciated.
Old 09-21-2011, 11:13 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I had the same problem with mine. Found that the shift lever hadn't gone all the way into the lock position. By pressing it further and making sure it was fully in Park I had no issues. Hope this helps.
Old 09-22-2011, 05:01 AM
Trim Level: st
Rep:14
thanks.. ill keep that in mind if it happens again and move the shifter out of and back into park
Old 01-11-2012, 03:47 AM
darowden's Avatar
darowden darowden is offline
Vehicle: 2011 Dodge Ram Crew Cab
Color: Deep Water Blue Pearl
darowden is on a distinguished road
2011 1500 ST Crew here.
Mine does the same thing. I found jiggling the shift lever a bit helps to release the key.
Old 01-11-2012, 10:33 AM
Hotrodbird Hotrodbird is offline
Hotrodbird is on a distinguished road
I had the same problem. I had a small wire for my phone charger got in front of the shifter and did now allow it to go fully into park. Man did I feel dum when I figured out what I had done. I hope yours is a simple fix like mine was.
Old 01-12-2012, 05:57 AM
Trim Level: st
Rep:14
thats what must of happened here too.........since that happened i made sure the shifter went into park and it hasnt happened since.thanks everyone
Old 02-21-2012, 10:01 AM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Just turn the truck back on. shift into drive then back into park and turn the ignition off. The key should pop out.
Had the same issues with mine.
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Key stuck in the ignition hemibenny 2011 Dodge Ram Forum 19 08-08-2012 07:19 AM
99 ram ignition problem andytcox 5.2L V8 Specific Topics 1 09-15-2011 05:58 AM
84 ignition mystery Larryz51 Newbie Checkin! 8 07-07-2011 12:09 AM
Ignition problem andrewdains Electrical 2 05-22-2010 02:35 PM
Anyone running MSD ignition box? Zekery360 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 0 10-12-2009 06:08 PM
