Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
tonneaucovered.com
Old 09-22-2011, 01:14 PM
monkmonkey monkmonkey is offline
Vehicle: 1998 Ram 1500
monkmonkey is on a distinguished road
Default 1998 Ram 1500 Question
Got a 98 ram 1500 5.2L 176kmiles. This is the problem...Starts easily, idles at 600rpm. When driving it will act like its running out of gas. This will usually happen just after 1/4mile of driving and last for 1/4-1/2 mile, although it has happened after 4 miles of driving then it will drive normally. As it seems to run out of gas, a loud clacking sound comes from the front end. I know the sound is not the engine as the truck needs new tie rods. What can you guess is the problem? Anyone else have this issue?
Old 09-22-2011, 09:23 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
fuel pump might be going out and not able to keep up with the higher rate needed when under speed. find a pressure guage hook it up drive the truck around see if the pressure drops when it starts to act up. the trick is to find a way to place the guage where you can see it.
Old 09-22-2011, 09:27 PM
ramfam's Avatar
Trim Level: Base
Rep:21
as for the noise in the front if it happens only when you hit bumps the ball joint might be the issue. dont take my word for gold but its a good place to start.
Old 09-24-2011, 04:28 PM
jimwww
Replace fuel filter? I have had one so dirty that it blocked fuel flow.
Will Dodge Ram 1500 2010 Wheels and Tires fit a 1998 Dodge Ram 1500? koalatyman Dodge Ram Wheels And Tires 1 04-14-2011 10:38 PM
1998 Dodge RAM 1500 4x4 Ext. cab - $6500 FloridaCracker352 Dodge Ram For Sale - Used Dodge Trucks 7 11-04-2010 10:54 PM
2008 Dodge 1500 Trany Question newdodgeowner Newbie Checkin! 12 07-27-2010 09:30 AM
Fuel pump in 96 Ram 1500 question markj 5.9L V8 Specific Topics 3 06-03-2010 04:35 PM
1998 trans. stick 5 sp. in 1997 1500 2 WD. WM300 V6 Specific Topics 0 02-26-2009 01:20 AM
