Old 09-22-2011, 04:39 PM
StriferZer0 StriferZer0 is offline
Vehicle: 2007 Dodge Ram 1500
Color: Metallic Silver
StriferZer0 is on a distinguished road
Default front parking light
I have a 2007 dodge ram single cab cannot figure out how to change the front parking light. the headlight has acccess but i cannot find a way to the parking light next to it.
Old 09-29-2011, 11:34 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and I sure wish I had an answer for you. Best I can do is this back to the top for you.
Old 09-30-2011, 07:32 AM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
You have to remove the whole light assembly.
REMOVAL
  1. Disconnect and isolate the battery negative cable
  2. Remove the push pins attaching the seal to the fender.
Fig. 9 Headlamp - Typical
  1. Remove the bolts attaching the headlamp unit to the fender.
  2. Remove the bulb sockets from the headlamp unit
  3. Separate headlamp unit from vehicle.
INSTALLATION
CAUTION: Do not touch the bulb glass with fingers or other oily surfaces. Reduced bulb life will result.
  1. Install the bulb sockets for the front park/turn signal and headlamp.
  2. Position headlamp unit in inner fender panel.
  3. Install the bolts attaching headlamp unit to the fender.
  4. Align the seal and install the push pins.
  5. Connect the battery negative cable.
Once you remove it there will be access to everything.
Hope it helps
3rd brake light leak fix snrusnak Dodge Ram Knowledge Base 77 06-17-2014 02:22 AM
LED underhood light mod Barnyard Custom Dodge Ram Interior and Exterior Lighting 11 01-23-2012 06:54 PM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
Front light bars? Ryank Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 11 09-07-2010 03:28 AM
Braking is lighting up front parking light?! iRESQu Electrical 12 09-01-2010 07:58 AM
