Old 09-22-2011, 06:12 PM
ShoreRider ShoreRider is offline
Vehicle: 2004 Dodge RAM 1500
ShoreRider is on a distinguished road
Default Blower motor speed
I searched the threads here but found no answer specific to my problem so here goes:
My blower motor was oeprating fine on all speeds up until 1 day ago. When I got into the vehicle and went to turn on the AC, none of the speed selection on the blower switch work except for the highest. I checked every damn fuse and relay under the hood and all are fine. Any thoughts as to what I'm missing from an electrical check perspective or is the whole blower speed switch faulty?
Old 09-22-2011, 06:17 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Sounds like the blower motor resistor went out, it is what the wires plug into on the blower motor, held on by 2 screws. I believe they run about $100-$125
Mike
Old 09-22-2011, 06:38 PM
I just removed the blower motor and see the 2 screws you are referencing, but don't see any way of accessing anything internal to the blower by remving those two screws. It is a completely molded housing. I'm assuming I'll have to remove the rotating blower and go at it from that way. May just be easier to go to a local junkyard and get an operational blower motor that way and replace the whole thing. Thanks for the quick response.
Ignition Switch and Fan Blower Problem steelman512 Electrical 13 09-22-2013 08:54 PM
Blower Motor Fix Dalton Heating & Cooling 3 08-23-2011 02:36 PM
Blower motor problems! Help IM HOT!!! M0PARMGNUM Heating & Cooling 4 05-14-2011 06:13 PM
AC blower problems mcline1968 Heating & Cooling 4 12-22-2010 11:34 AM
2005 Dodge Ram 1500 blower? TroyH04 Heating & Cooling 7 11-27-2010 05:05 PM
