Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 09-22-2011, 08:40 PM
tat2dwiseguy's Avatar
tat2dwiseguy tat2dwiseguy is offline
Vehicle: 2012 RAM 1500 SPORT
Color: Deep Cherry Red Pearl
Rep:64
tat2dwiseguy will become famous soon enough
Default What is it and why is it there?
There is one of these installed on each frame rail of my 09 crew cab. They look like counter weights or harmonic balancers. What are they reqally and why are they there?
Old 09-22-2011, 08:52 PM
DOZER's Avatar
DOZER DOZER is offline
Vehicle: 2009 Ram 2500 Quad cab 4x4
Color: Inferno Red
Rep:140
DOZER will become famous soon enoughDOZER will become famous soon enough
Send a message via Yahoo to DOZER
Can you post a pic?
'06 2500 ST 4x4 Quad cab, Vararam CAI, Bed/Hood stripes, Vent visors, Bully tailgate lock, Moto Metal 909 18x9, Nitto Terra Grapplers 295/70/18 HBS 2" level, Bilstein 5100's, Bushwhacker flares, 5000K HID's, Diablo Trinity 87 tune, LineX, Bakflip F1.
Old 09-22-2011, 09:19 PM
scmedic09's Avatar
scmedic09 scmedic09 is offline
Vehicle: 2010 dodge ram
Color: Brillant Black
Rep:168
scmedic09 has a spectacular aura aboutscmedic09 has a spectacular aura about
man i got these on mine, no idea what the heck they are used for
Old 09-22-2011, 09:58 PM
Rep:64
I know I had a lot of underbody turbulence / vibration on my 2003 Ram. I wonder if these were some attempt at controlling that? But their design, with the rubber sleeve inside, seems to be more of a harmonic control. Quite confusing.
I pulled this one off because I am chasing an annoying clunk on the passenger underside and cannot for the life of me locate it. I am pulling off everything non-essential.
So far I have tightened the exhaust clamps (mutiple times, even added extra clamps at the front mufler joint), tightened the rubber exhause hangers, found a broken exhaust clamp (just below the passenger manifold), found a nearly dislodged heat shield (same side), tried running without the spare in place, without the tailgate, without the tonneau cover, took the bedliner out, emptied every single item out of my truck, to include the in floor storage liners, tried the passenger seat reclined trick, ran with the rear seats and under seat storage trays in the up/open position....NADA... still clunkin'!
Anyone else have a clunk? I had my tie rods replaced and that resolved a small clunk I could feel in my brake/gas pedals (along with the terrible steering/shake), and they replaced my driveshaft due to a leak at the yoke, which I thought might have had some lash contributing to the clunk, but no such luck.
It's driving me nucking futs... it's the only aspect of the truck I don't enjoy, and since it's pretty much constant while I'm driving it (the slightest bump causes it), it's hard to ignore. Dealer and a friends shop have had it in the air a few times and nobody has had any success locating an issue. Next step is dropping the entire exhaust, cat back. Only problem is I think it will be too loud to hear the clunk if it still exists.
Any suggestions are welcome!
Old 09-22-2011, 10:11 PM
hack99's Avatar
hack99 hack99 is offline
Vehicle: 2011 Ram RCSB 4x4
Rep:34
hack99 is on a distinguished road
You'll have to strap yourself under the truck and have a buddy drive it. Should be able to pin-point it that way. (I jest, please don't)
A noise like that could be a bushing; sway bar front/rear, upper/lower shocks etc. Enough to drive ya nuts.
Old 09-22-2011, 10:13 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
they tone down the NVH (noise, vibration, harshness). I took them off my car and didn't even notice a difference. They are still on my truck but then again I'm not worried about removing every extra pound possible on the truck.
do a google search for something along the line of "NVH reduction" or "NVH weights" and you find it other forums....mostly muscle car ones because it's fairly common to remove them from the frame, axle or where ever to loose a couple pounds.
Old 09-22-2011, 10:50 PM
DenDen's Avatar
DenDen DenDen is offline
Vehicle: 2011 ram 1500 4x4
Color: Hunter Green
DenDen is on a distinguished road
They are vibration dampeners.We use something similar to this on the power lines to stop the wires from galloping in the wind.
2011 Dodge Ram.Hunter Green Crew Cab,Hemi.20 inch wheels.Bought August 28 2011.
Old 09-22-2011, 10:55 PM
Rep:64
We've had a wrench or prybar on every suspension part, I even replaced the shocks with Bilsteins. I had a mechanical "ear" that you can clamp to certain chassis parts and listen via remote. I tried that on about 16 locations and nothing. I'm starting to think it's a broken body brace or something in the bed or passenger door, since I can't locate it under the truck. What pisses me off is that the service writer will always delete the "customer complains of clunk" from the service report since they can't locate it. I think they're trying to cover their ass or avoid a lemon law case.... not that I would give back my truck, but for crissakes, they missed the broken clamp and heat shield.... are they even looking????!?
Old 09-23-2011, 09:29 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
Mine did it too, its your cab mount bushings, they need replacing. that clunk you hear, is your cab shifting on the bushings/frame when you turn or hit a bump. Look at them from under the truck and if they are dryrotted then they need replaced. Its relatively easy, provided you dont live in salt country. Take a floor jack, and position it on the side of the cab between the rocker panel and the frame rail. place a 2x4 or 2x6 (preferably the latter) in between the jack head and the cab floor. Jack until snug. Remove bolt#1, jack cab up SLIGHTLY, remove and replace bushings. Repeat 3x on all corners. The fronts are a little trickier with the pack positioning but it can be done. Be careful not to damage any fuel lines or trans cooler lines which may run along the floor.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
