Old 09-22-2011, 09:55 PM
2000RAM's Avatar
2000RAM 2000RAM is offline
Vehicle: 2000 Dodge Ram 1500
Trim Level: sport
Color: yellow
2000RAM is on a distinguished road
Default More lift
hey guys. just wondering if anyone has any ideas on how to lift my truck more. i have a 5.5" fabtech lift now. i dont want to do a body lift but i want my truck higher. anyone got any ideas???
Old 09-22-2011, 10:15 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Well i would highly recomend not putting spacers on top of your current lift. Its just a terrible idea
Old 09-22-2011, 10:40 PM
2000RAM's Avatar
Trim Level: sport
Color: yellow
what about doin coil spacers like from a leveling kit. and 1 7" block in the rear. not stacking blocks
Old 09-23-2011, 12:02 PM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
what about adding Bilstein 5100's
Old 09-23-2011, 01:12 PM
Color: Mineral Gray
Rep:177
Pretty much exactly what you dont want to do. Almost every lift man. says not to do it. that being said there is a Cummins running around by me with a 4" fabtech with 3" top gunz spacer on top of it, I just shake my head everytime I see it. If you dont off road with your truck its not as bad but still not safe.
A 7" block is just asking for problems.
Cant do bilstiens 5100s ride height adjustables with straight axle trucks.
Really the only right way to go higher would be to go with a new lift.
Old 09-23-2011, 01:25 PM
marshallsmith44 marshallsmith44 is offline
Vehicle: 2007 dodge ram 1500
Rep:74
marshallsmith44 will become famous soon enough
^ true to a extent, if you just do a 1'' or 2'' spacer chances are you will be fine as long as your not wheeling your truck but really i would just say get a body lift with gap guards that would give you 3'' more and not cause any issues. there are a ton of people with spacers on top of the lift with 0 problems but there also are people who have problems getting aligned and what not
Old 09-23-2011, 10:40 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
How much lift do you want? There's a new long arm lift from Top Gun Customs that should be out soon that can give you up to 6.5 inches.
If you really want to go cheap a front spacer and rear shackle flip should net you enough. Make sure your rear axle is centered in the wheel well...you may need a zero leaf to accomplish that. Don't blame us if you can't get your alignment set and the truck handles like crap.
I would also avoid blocks like the plague. Too much potential for parts breaking axle wrap.
BTW, if this is for tires over 35 inch and you offroad your truck, you'll find your 1/2 ton axles will start giving you issues. Not a matter of if, but when.
Old 09-25-2011, 04:33 PM
2000RAM's Avatar
Trim Level: sport
Color: yellow
i want higher than 6 inches. i really dont want to do a body lift.
Old 09-26-2011, 02:25 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
Do 5100's and a spacer on the rear.
Old 09-26-2011, 03:03 AM
Color: Mineral Gray
Rep:177
Post
That's not an option with solid axles and leafs in the rear
Trying to get the most height mustang26 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 10-16-2011 07:38 PM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 10:49 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 11:25 PM
2010 Ram 1500 4X4 Lift Help! Cap10crch 2010 Dodge Ram Forum 6 03-02-2010 12:28 PM
Suspension lift vs body lift usmcoorah Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 06-19-2009 01:13 AM
