Old 09-23-2011, 01:35 PM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
Default 4TH Gen: Stock Alpine Door Speaker Specs
Here are the detailed measurements of the stock Alpine door speakers:
Door: 6x9" speakers with a 2.0 ohm rating (2 1/2" depth)
The front speakers have a midrange only, crossover affected frequency range. No high frequencies.
The rear speakers have a full range signal.
For removal of the speakers, the door panel has to be removed. This is easily accomplished by:
  • Prying open the little circle inside of the door handle and removing the phillips head screw. Also gently pry out the plastic handle cover.
  • Then remove the plastic screws and retainers from around the door panel with a Torx 20 tool.
  • Remove the sail panel above the door panel, by the mirror. Just gently pry as it's held in by clips only.
  • Gently pull the door panel outwards and then up. Before the panel will come off, release the wiring harness from underneath the switch panel while it's still in the panel. There's no need to remove it. Finally, lift the panel over the door lock pull and set aside.
The speaker is held in place by four bolts which can be removed with a 3/16" socket.
For ease of replacement, use Crutchfield harness #12071050 on all of these speakers.
http://www.crutchfield.com/p_1207105...s.html?tp=3097
2012 R/T 392
Old 09-23-2011, 01:54 PM
It's stuck but I can't guarantee it will be right next to your other posts.
Old 09-23-2011, 01:59 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
No problem. Thank you!
2012 R/T 392
Old 09-25-2011, 02:11 PM
Frank Drebin Frank Drebin is offline
Vehicle: 2011 RAM CC SPORT
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:34
Frank Drebin is on a distinguished road
Hey Ironchef, great info, thanks for posting this up!
A question for you:
How were you able to verify that there was full range frequencies sent to the rear speakers? I ask because I used a temporary LOC for my subwoofer amp, and thinking that the front door speakers were from 20hz to say 500...but the subwoofer performed poorly. When I tapped into the subwoofer feed with the LOC the aftermarket amp/sub combo performed a lot better.
This led me to conclude that the front doors are filtered from maybe 100hz to 500hz, with the subwoofer doing all the sub 100hz duties, which would lead me to believe that the rear doors would also do a filtered full range from 100hz to 20khz, but not below 100hz.
Three Generation Dodge Ram Owner - 1998, 2003, 2011
Old 10-02-2011, 09:20 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
Hey Frank,
I used a set of JL C2-650 separates and a test CD with specific frequency test signals. The rear doors are sent a different filtered frequency than the fronts. When I connected my C2-650 separates to the front, the tweeter was obsolete. It was able to reproduce frequencies up to 800hz and all the way down to 20hz. On the rear, the tweeters performed, but not to their full potential. It faded off after about 7000hz and again, down to 20hz. When I say "full frequency," I mean that it has a broader frequency range.
This would explain why people have had success with a quality set of components or coaxials in the rear doors, but not in the front.
Bear in mind, just because a speaker is able to reproduce a signal at 20hz, it doesn't mean it's not equalized. There's probably a very basic crossover on the sub 100hz frequencies with only a 6db roll off. Therefore, it'll play the signal but weakly, which would explain your sub wiring scenario.
2012 R/T 392
Old 06-14-2012, 10:30 PM
Mophead's Avatar
Mophead Mophead is offline
Vehicle: 2012 2500 4x4 Crew
Trim Level: Bighorn
Mophead is on a distinguished road
Could we get a pic of the speakers without the dust covers please? Just curious about the construction of the originals. Thanks.
Old 09-03-2012, 02:31 AM
Mophead's Avatar
Trim Level: Bighorn
I was wondering about buying a 6.5" component set for the front doors and installing the tweeters in the headliner spots. Does this make any sense? Did you measure the frequencies for the headliners? I assume I wouldn't need to use the crossovers that come with the speakers since they're already there. Is this correct? I'm trying to upgrade a little at a time, I can't afford it all at once. I was thinking to do the speakers first then a processor and amps later. I already did the dash and am very happy with the results. Will probably do the back doors next, then front and headliners if I can indeed install tweeters there now. appreciate any help you can give me. Thanks.
Old 12-19-2012, 06:01 PM
gain11's Avatar
gain11 gain11 is offline
Vehicle: 2009 Dodge Ram
Trim Level: Laramie 4x4 Crew Cab
gain11 is on a distinguished road
ironchef did it look like the doors could take a deeper speaker. I know the C2-650's have approximately the same mounting depth as the stock Alpine 6x9's. Everything i'm considering is between 3-1/4" and 3-1/2" deep............did it look like there's another inch to spare in there?
Old 09-18-2013, 12:47 PM
wilk wilk is offline
Vehicle: 2011 Ram 1500
Color: Black w/Camo trim
wilk is on a distinguished road
Do you know if a pioneer 4way 6x9 with a 4" depth will fit in the front door?
Old 01-11-2014, 05:33 PM
Trackstand's Avatar
Trackstand Trackstand is offline
Vehicle: 2013 Ram 2500 CC LB 4X4
Rep:73
Trackstand will become famous soon enough
So whats in doors? sounds like the fronts are 6.5 bass and midrange only and the rears are 6X9 full range? thanks
2010 1500 5.7L Single to Dual Exhaust plus Intake??? NewfieRam1500 Exhaust 26 04-07-2014 01:45 PM
2011 Ram R/T alpine upgrade (calling chithead please) JoeHemi57 Custom Dodge Ram Interior Modifications - Custom Audio / Video 4 05-28-2011 12:30 PM
Adding an Amp and a Sub but KEEPING the stock head unit? RammD Custom Dodge Ram Interior Modifications - Custom Audio / Video 14 08-18-2010 07:39 PM
Anyone with stock Alpine, Swap to Quality Spekaers but Retain the Amp? RammD Custom Dodge Ram Interior Modifications - Custom Audio / Video 22 08-12-2010 09:45 AM
Stock AMP is Alpine?...and location? RammD Custom Dodge Ram Interior Modifications - Custom Audio / Video 5 08-04-2010 08:27 PM
