Old 09-23-2011, 04:35 PM
HOTHEAD's Avatar
HOTHEAD HOTHEAD is offline
Vehicle: 2009 1500 Quad SLT
Color: Black on Black
HOTHEAD is on a distinguished road
Default Fog bumper swap
PLEASE don't flame me...
I have used the search function, and come across multiple threads on this, however between reading pages upon pages about this I still don't have complete answers.
I recently had an accident and convinced the body shop to install the factory fog cut out bumper on my 09 Quad slt that previously had just the solid chrome front bumper. Now I have begun the process to complete the swap. My questions are, has anyone actually completed this swap? Most of the threads I have read are incomplete, and if there is a thread with alot of details listed, please feel free to post the link.
Basically, I have a few questions. I have located the OEM part kit with the wiring, lights, and switch on a few different sites including ebay. Oddly enough, I think my truck has the proper switch already installed (at least that is what I think) it has a small push button switch underneath the headlight switch. Also, I keep seeing referance to "mounting brackest" for the lights, but have been able to locate a part# for them (are these hard to install?). Does anyone know if the wiring harness is plug and play? or do I have to splice them in? If so, any idea about where to locate the wiring diagrams? Lastly, a link to a exploded diagram of the fog bumper assembly might even warrant a sincere thank you
I just figured I'd ask if anyone had some knowledge of this swap before I get started.
As always, thank you
Regards
Old 09-23-2011, 07:12 PM
brokenwrench66's Avatar
brokenwrench66 brokenwrench66 is offline
Vehicle: 2009 1500 SLT 4X4
Color: Stone White
Rep:81
brokenwrench66 will become famous soon enough
I know there`s a detailed thread on this because I looked at it when I was trying to decide if I should do this. Maybe some of what I learned will help you.
All of the kits I`ve seen on ebay are for the fog lights that mount down in the lower bumper, beside the tow hooks, not in the fog lamp cut-outs.
The switch your referring to in your truck is most likely your cargo light switch. I`m pretty sure that you`ll only have the right switch if you already have the fog lights.
The part number for the mounting brackets is 68054374AB. Needless to say you`ll need two (there`s no left or right).
I believe the wiring harness is plug and play but you should double check that.
Check here:
http://www.jimsautoparts.com/mopar_p...&_exterior.htm
and you`ll find an exploded view of the bumper and a listing of all the parts you`ll need.
Good luck!!
Dual Exhaust, K&N drop in, TFP chrome mirror covers, TFP stainless steel door handle covers, molded splash guards, Leer cap
Old 09-23-2011, 07:16 PM
Good info ^^^^ and I'll add that if you want the fogs to operate, you'll need to go see the dealer after the install and have the PCM flashed.
I strongly suggest you use the factory harness and switch. The factory stuff will truly be plug and play.
Old 09-23-2011, 09:51 PM
Color: Stone White
Rep:81
You`re right MADDOG! I don`t know how I forgot about that!! I hear with the 2012s you have to get a re-flash when you fill the tank to let the gas gauge know you have new fuel in the truck!!
Old 09-26-2011, 01:43 PM
HOTHEAD's Avatar
Check here:
Good luck!!
Thanks, great link. I am ordering parts today, and will update post as I go
Old 09-28-2011, 05:07 PM
OMALLEY808 OMALLEY808 is offline
Vehicle: 2009 Dodge Ram SLT
Color: stone white
Rep:64
OMALLEY808 will become famous soon enough
Thanks for the info. I want to do this soon!
Bumper Swap Question AKRAM Body & Interior 3 05-24-2011 12:10 PM
Sport bumper to regular bumper swap.... skoal Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 25 03-15-2011 11:38 PM
SLT to Sport Bumper Swap 916Timmy Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 4 01-17-2011 09:51 PM
Bad Front Bumper Fascia Replacement/Repair BigEmpty Body & Interior 21 12-01-2010 07:40 PM
Hmmm, bumper swap?! GregInAtl Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 3 10-25-2010 12:34 AM
