Old 01-29-2012, 05:23 PM
BgHrn BgHrn is offline
Vehicle: 2006 Dodge Ram
BgHrn is on a distinguished road
Ah, alright then. Thanks!
06' Ram, molding!, In-channel visors, 3" Mag' SI/SO 18" long, Mag' y-pipe, 2" HBS Leveling kit/1" rear block ,DSP 91 tune, KN CAI kit, BFG 285/65r20 rubber.
Old 01-30-2012, 11:26 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I've had mine for a while...no issues
Old 01-31-2012, 05:23 PM
Vehicle: 2012 Dodge Ram Sport
Rep:47
Will this work on the 2012 six speed? I contacted the company that you bought yours from and they said they would contact sonnax and get back with me and they haven't.
Old 01-31-2012, 05:57 PM
heavy2500's Avatar
heavy2500 heavy2500 is offline
Vehicle: 2003 Ram 2500/ 2005 Ram 3500
Color: grey
heavy2500 is on a distinguished road
Its for the 545rfe trans witch is an auto.
Old 01-31-2012, 06:22 PM
Whitehemi Whitehemi is offline
Vehicle: 2012 Ram
Rep:17
Whitehemi is on a distinguished road
I have a 2012 with the so called 6 speed and it worked .Plug right in .....
Old 01-31-2012, 07:13 PM
2500hd's Avatar
2500hd 2500hd is offline
Vehicle: 2010 Ram 2500 HD
Color: Austin Tan
Rep:32
2500hd is on a distinguished road
I was able to obtain one from sonnax at sema and for the first couple weeks I could "feel" the difference on my daily drive to work. After a few months now it feels the same as it did before I put one in. I use to be able to feel the firm shift and now its just a smooth shift like before. At this point I may remove mine just because its not really gaining anything but its not hurting anything either so I might as well do without as i'm not out any money on it. Just sharing my experience.
-Amp Research-Fuel Offroad-Nitto-Diablo-Rigid Industries-Craven-CJC Offroad-Carli-BT-
Old 02-01-2012, 12:26 AM
916Timmy's Avatar
Rep:1443
^^^thats what TransEngineer is getting at too...mine feels pretty normal now too! I want to take mine out and see if it starts to slip
Old 02-01-2012, 01:53 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
So....I've been doing some experimenting, and found some interesting (although not conclusive) results. All the tests were run with NO trailer and minimal payload.
I removed my tune and the Sonnax...at the same time. Truck ran like garbage and shifted ultra sloppy for about 1 minute, then started to sort itself out. The shifts were ultra smooth, and the shift time was IMO quite long. I kept it like this for a couple of days, >100miles and 15+ start cycles. On the 3rd day, I reverted to manual shifting and aggressive driving. Within a few minutes (3-4 starts from a dead stop), the trans started to shift a bit more aggressively and faster, and the engine seemed happier. I kept this up for a couple of days with a good mix of city/highway and many start cycles.
I then installed the Sonnax and immediately noticed a difference. Shifts were fast and firm.....for awhile. After 5 starts cycles and 30+ starts from a red light, I noticed the shifts were decreasing in firmness. By the end of the first day, it felt like I have never installed the Sonnax unit at all!! Didn't matter whether I ran easy or aggressive, the results were about the same as without it.
I then removed the Sonnax unit, and trans shifted terribly (even noticed a bit of slippage) for about 2 starts from a dead stop. Then it was back to 'normal'.
Next day I installed my 91 tune, which was really noticeable! The trans seemed to shift firmer, so I drove like granny for 2 days, and although it softened slightly, it never got as soft as without the tune. I then switched to 'lets have fun mode' and after a few minutes manual shifting, etc. it firmed up, and sped up slightly...but noticeable.
I then installed the Sonnax, and the first shift out of the lot broke the tires loose. Now that's not very impressive when you consider how slippery the roads are, but was certainly much firmer than it was 5 minutes before that.
I have left it in that configuration since, and the soft shifts after 'granny driving' for a couple of days (That was really hard to do when all you want to do is drive 'normal'), were firmer then the firmest shift attained in 100% stock mode. When I then opted to drive 'my normal', the firmness of the shifts returned within minutes.
In conclusion - I have absolutely no idea what is all happening, but believe the tuner is affecting the transmission, and under the conditions I present to my truck with my driving style, the Sonnax unit is making a difference that pleases me. But it only appears to do so when I have a non-OEM tune in the PCM.
With the tune out of the system, I experienced results that fully support what TransEngineer mentioned about how the trans will adapt.
I'm looking forward to further experiments this summer that will hopefully include a comparison between SuperChips and Diablo. It is my understanding that SC allows for some trans modding that is currently not available to me with my current tuner. I also hope to install a mechanical trans pressure gauge to see what is actually happening.
brad
Interested in one of my mods?
Old 02-01-2012, 02:30 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
SO in short stay away from the sonnax with a tune thats what killed my tranny about a year ago...
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 02-01-2012, 12:58 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
great info Brad, ive read so much with this post and the info is amazing, but i def will stay away from this
-Pat-
sonnax pressure booster
Sonnax Line Pressure Booster? JasonK94Z 5.7L (345 cu in) HEMI V8 Specific Topics 11 09-10-2011 08:57 AM
Sonnax Electric Line Pressure Boost Pull Ya 5.7L (345 cu in) HEMI V8 Specific Topics 5 05-13-2011 06:26 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 05:29 AM
Sonnax Line Pressure Booster and Jet Stream Scoop, Installed ScatPak07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 9 11-22-2010 06:26 PM
Sonnax Line Pressure Booster MotorCityRam 5.7L (345 cu in) HEMI V8 Specific Topics 5 02-25-2010 10:47 PM
