Old 06-01-2012, 04:17 PM
rt9602 rt9602 is offline
Vehicle: 2005 Ram 1500 Q cab
rt9602 is on a distinguished road
BTW, the Sonnax is not required if you want to get a custom Diablo tune done
So, the "canned" TCM tune from the DiabloSport will not affect line pressures to any noticable amount?
I've been running the TCM Performance tune with the Sonnax. I was going to remove the Sonnax - let a friend try it on his but figured I'd best de-tune off the DS, drive it a bit then remove it so as to not totally confuse the trans... thoughts?
Old 06-01-2012, 04:21 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
After removing the sonnax you need to do the relearn procedure for the transmission. Otherwise your line pressures will be way low.
Sean
Old 06-01-2012, 04:43 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
To mess with line pressures with a DiabloSport, you need a CMR tune. It's not in the canned tunes.
The first few shifts with the Sonnax will hit hard, but the computer smooths them out...then if you take it off, the will be way soft and slip.
Old 06-10-2012, 08:16 AM
VIPDHEMI's Avatar
VIPDHEMI VIPDHEMI is offline
Vehicle: 2010 Dodge Ram R/T
Trim Level: R/T
VIPDHEMI is on a distinguished road
So should I just take out my sonnax and put it beside my throttlebody spacer in my random nonsense drawer in my tool box? Or just leave it in since its not hurting anything really?
ARH Headers,AirRaid CAI,ported TB,DSP 93 tune,BT catch can,2/4drop,tint,14"maggy,resy's removed
Old 06-10-2012, 07:26 PM
snrusnak's Avatar
Rep:1385
Up to you but I'd personally take it out. Some people report that they have other issues with them. You will want to do the relearn procedure though when you remove it.
Sean
Old 06-10-2012, 07:43 PM
InDeepWaterBlue's Avatar
Rep:611
Agreed, the computer negates that line booster after a while.
Old 06-10-2012, 11:08 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Unless you have a pre-2011 and are using a tuner. Then the sonnax makes a notable difference.
brad
Interested in one of my mods?
Old 06-10-2012, 11:14 PM
Rep:611
Good catch Brad just realized he had a 2010 Ram, so you could definitely get a tuner if you wanted to keep the Line Pressure Booster.
Old 06-11-2012, 08:05 AM
snrusnak's Avatar
Rep:1385
How is that....?
Sean
Old 06-11-2012, 02:43 PM
brad12kx's Avatar
Rep:2581
With my DS tune, the Sonnax is both noticeable and the shifts don't seem to 'adapt' as they do without it. Even if I granny drive for awhile, they stay firm. Without the tune the PCM appears to adapt to the Sonnax and reduces the pressure.
I am hoping to hook up an actual pressure gauge to monitor what is going on, but for now I'm very pleased with the combination of DS tune and Sonnax. The shifts are firm enough to chirp the tires on both the 1-2 and 2-3 shifts on hot pavement under WOT. Without the Sonnax, that never happens.
brad
sonnax pressure booster
Sonnax Line Pressure Booster? JasonK94Z 5.7L (345 cu in) HEMI V8 Specific Topics 11 09-10-2011 07:57 AM
Sonnax Electric Line Pressure Boost Pull Ya 5.7L (345 cu in) HEMI V8 Specific Topics 5 05-13-2011 05:26 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Sonnax Line Pressure Booster and Jet Stream Scoop, Installed ScatPak07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 9 11-22-2010 05:26 PM
Sonnax Line Pressure Booster MotorCityRam 5.7L (345 cu in) HEMI V8 Specific Topics 5 02-25-2010 09:47 PM
