Sonnax 545RFE Line Pressure Booster - Page 20 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 06-22-2012, 08:57 PM
thunder98110's Avatar
thunder98110 thunder98110 is offline
Vehicle: 2012 Dodge Ram
Trim Level: ST express
Rep:14
thunder98110 is on a distinguished road
i had one on my 45rfe dakota. loved it, shifted hard everytime at WOT for over a year. its a resistor, the pcm wont relearn and go back to stock shift pressure.
2012 RCSB, Hemi,3.92,2wd,Fastman TB,180tstat,K&N CAI,AeroTurbine 3030xl + Magnaflow Y,v6efan, LEER 100xl
Old 06-27-2012, 07:46 PM
02D2 02D2 is offline
Vehicle: 2002 dodge durango
Color: grey
02D2 is on a distinguished road
Before I put the sonnax on my trans, when I would cruise the hwy, whenever
I tried to speedup while in lockup, it would feel like my engine was
free revving and the rpm would shoot upwards as if the engine divorced itself from the rest of the vehicle.
Then after about a second it would feel and sound like someone hit me in the back then gears would engage and the vehicle would takeoff.
But ever since I put the sonnax in about 800 miles ago, it has only happened
once .
Old 06-30-2012, 10:40 AM
RAM-RT's Avatar
RAM-RT RAM-RT is offline
Vehicle: 2011 Dodge Ram R/T
Trim Level: R/T
Color: Metallic Grey
Rep:29
RAM-RT is on a distinguished road
I got my Sonnax the other day and I tested it out. It seems to shift faster and a little firmer than stock, but not to harsh. I like the way it shifts. Lets hope it stays like this and the PCM wont learn it.
Old 07-23-2015, 07:57 PM
Daddydaycare Daddydaycare is offline
Vehicle: 2003 Dodge Ram
Color: Grey
Daddydaycare is on a distinguished road
Just ordered my sonnax. Looking forward to feeling the change
Old 07-28-2015, 08:28 AM
HammerHead's Avatar
HammerHead HammerHead is offline
Vehicle: Ram 1500
Rep:20
HammerHead is on a distinguished road
I'm still waiting for them to make one for the 65RFE 6 speed.
Geared-Tuned 0-60 in 4.82
Proud member of the 4 second club...
Old 07-28-2015, 08:36 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:518
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
Anything that works on the 545RFE will also work on 65RFE. These transmissions are identical hardware-wise.
Old 07-29-2015, 06:33 PM
HammerHead's Avatar
Vehicle: Ram 1500
Rep:20
Thank you for that info; I do have another question tho. I just had my Valve Body worked by Superstreet performance and wanted to know if this would be a good addition to the upgrade they did? Mid to high it digs Very hard and performs very well but I defiantly lost some low end torque. It shifts very fast but not as hard as it did with the stock VB. I see the sonnex increases clutch clamping force to increase torque capacity, was wondering it that would help with my low end loss. Any advice please?
Old 07-30-2015, 07:32 AM
Vehicle: N/A
Rep:518
Raising line pressure (and/or increasing clutch capacity) will not correct a low end torque loss.
However, I'm having difficulty understanding how a valve body rework would cause low end torque loss in the first place. I'm thinking that "low end torque loss" means either the engine torque decreased (which a VB rework would not affect), or the shift pattern changed such that you no longer get a kickdown at low speeds. But the shift pattern is controlled by the TCM/PCM, not the VB, so again I don't see how a VB rework would change this.
But in any event, raising line pressure will not increase the engine torque, or change the downshift pattern, so I don't think it would help.
Old 07-30-2015, 08:20 AM
HammerHead's Avatar
Vehicle: Ram 1500
Rep:20
Thank you for the response. I still can't make since of it, nothing changed on the truck; I just dropped the VB sent it out and put it back in. The truck doesn't run bad at all but before the VB work I could roast the tires from a 10-15 MPH roll and always had traction issues. But, spinning is isn't winning so maybe it will be a blessing once I hit the track. Thanks agin for the response
Old 07-30-2015, 11:33 AM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
Have you called Jerry an asked him about your problem since the new VB?
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected. Remember, going fast costs money, so how fast do you wanna go?
Semper Fi Forever
sonnax pressure booster
Sonnax Line Pressure Booster? JasonK94Z 5.7L (345 cu in) HEMI V8 Specific Topics 11 09-10-2011 07:57 AM
Sonnax Electric Line Pressure Boost Pull Ya 5.7L (345 cu in) HEMI V8 Specific Topics 5 05-13-2011 05:26 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Sonnax Line Pressure Booster and Jet Stream Scoop, Installed ScatPak07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 9 11-22-2010 06:26 PM
Sonnax Line Pressure Booster MotorCityRam 5.7L (345 cu in) HEMI V8 Specific Topics 5 02-25-2010 10:47 PM
