Sonnax 545RFE Line Pressure Booster - Page 4 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 09-26-2011, 10:01 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Update:
I talked to superchips this morning and they said we should have no issues with using the superchips along side the Sonnax resistor product that does the line pressure increase. He confirmed the superchips does not alter line pressures.
Sean
Vehicle: 2010 Ram RCSB 4x4
Rep:561
Originally Posted by ram71351 View Post
Brad, to add to that problem, it resets back to normal every time you turn the truck off (or cycle the key). So really its useless and I found no difference. I dont even use it. Sorry to thread jack....
If you have a remote start you can use that to restart your Ram and the disable is not reset. It's only a key start the resets it.
The prime benefit is for Offroad use only (Track or Trail),
says so right on the screen when you use it...
When I turn my TC off I can smoke both rear tires for over 20'
...RCSB 4x4 on 305/50R20 Grapplers, 3.55 open rear diff.
...and yes, those are my donut marks too
Old 09-26-2011, 10:11 AM
Rep:561
Update:
It's the ones with TM settings altered that were reporting issues...
Originally Posted by myoung84 View Post
Anyone running the Sonnax with the Superchips trans tune with reduced TM? My TM is set at 8% now. If I order one of these, what should it be set at?
Originally Posted by Loadedlaramie View Post
I am, but I'm currently having an issue with my TM settings, I've got a work ticket to SC but nothing yet.
I've been running a sonnax with tuner and trans tune since febuary and love it, it snaps shifts, I've barked tires goininto 2nd before. But my cortex seems to not be applying the TM settings now and won't let me change any user settings. I had all mine set to around 6%
Old 09-26-2011, 10:17 AM
snrusnak's Avatar
Rep:1388
Ok gotcha.
I also found out while talking to them that the torque management options for my 4.7L differ than those of the 5.7L. I can not actually adjust the TM settings(percentage) on my truck, I can only set it to "stock" or "superchips". What the "superchips" setting does is alters the amount of time the program takes to complete the shift which makes the shift firmer. Apparently the programming for the shift has a preset duration, and the tuner shortens the duration.
I believe with the 5.7L I believe you can also adjust the percentage of the TM. This option is not available for the 4.7L.
Sean
Old 09-26-2011, 10:24 AM
Rep:561
Ok gotcha.
That's what I was trying to explain yesterday
Superchips tuners are the ones that allow a different percentages of Torque Management adjustment at the user level.
...that "some" claim are causing a conflict with the Sonnax line pressure booster on the "other" forum (DT)
and those are the ones with Sonnax issues
Guess you missed that.
Old 09-26-2011, 12:59 PM
Racerdamon's Avatar
Racerdamon Racerdamon is offline
Vehicle: 2010 Dodge Crew Cab
Rep:145
Racerdamon will become famous soon enoughRacerdamon will become famous soon enough
Thanks for the info, I just ordered mine from Transmission Parts USA and they shipped it today.
Old 09-26-2011, 05:05 PM
johnnyG's Avatar
johnnyG johnnyG is offline
Vehicle: 2004 Dodge Ram
Trim Level: Hemi Sport
Rep:34
johnnyG is on a distinguished road
ok. i got mine and i have an SC tune. i will install it in about an hour and report back. i have my TM at 8.8% its an easy enough mod that it can come off in no time. if it doesnt work out well i can always sell it here to someone with a DSP.
SC 3865, K&N CAI, Fastman TB, Magnaflow Y to 18", sonnax, Zeon LTZs, Bilstein HDs, LEDs everywhere, sylvania ZXE heads and fogs, shorty antenna, all aftermarket audio and subs, linex, ez down tailgate and lots and lots of love.
Old 09-26-2011, 05:14 PM
ORT's Avatar
ORT ORT is offline
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
Youll be fine. I have been running the SC and Sonnax together for a while now. And I have put a lot of hard miles on the combo without issue.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 09-26-2011, 06:23 PM
snrusnak's Avatar
Rep:1388
johnnyg if it doesn't work out for you let me know I'd probably buy it from you.
Sean
Old 09-28-2011, 06:02 PM
Racerdamon's Avatar
Rep:145
Just recieved this, pluged it in in less than a 2 min (hard to get my belly under the lowered truck) I havent tried it but ill post if I notice a diffrence.
sonnax pressure booster
Sonnax Line Pressure Booster? JasonK94Z 5.7L (345 cu in) HEMI V8 Specific Topics 11 09-10-2011 07:57 AM
Sonnax Electric Line Pressure Boost Pull Ya 5.7L (345 cu in) HEMI V8 Specific Topics 5 05-13-2011 05:26 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Sonnax Line Pressure Booster and Jet Stream Scoop, Installed ScatPak07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 9 11-22-2010 06:26 PM
Sonnax Line Pressure Booster MotorCityRam 5.7L (345 cu in) HEMI V8 Specific Topics 5 02-25-2010 10:47 PM
