Old 01-03-2012, 09:30 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
Uh oh so it this a waste???
-Pat-
Old 01-03-2012, 09:55 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Just an FYI to all looking into this, the transengineer on the forum mentioned that the pcm would most likely automatically "correct" line pressures to the factory settings after some time...
Nope.....won't happen! The PCM doesn't know the pressure is different, as this unit is sending the PCM altered pressure information. If the PCM was able to react to this and alter the pressure down to where it was, then it would do the same without it, and that would cause the trans to burn up prematurely under normal driving conditions.
The opposite! Probably the best mod you can do for your truck at any price. The increase line pressure is not at all damaging, but rather to opposite. Hard shifts don't hurt transmissions, soft shifts do, as soft shifts cause heat and wear, which are pretty much the only things that kill a trans.
Why are factory shifts so soft then you ask????
The factory is too busy trying to make the trucks drive like a car, and nice soft virtually unnoticeable shifts is just one of those 'car' things that they did. Unfortunately, some of these 'car' things have a dark side, and those of use that drive hard and/or pull trailers are seeing lower transmission life then we should.
Do NOT hesitate. Spend the $50 and have the piece of mind knowing you just increased the life of your trans, and can finally 'feel' the shifts.
brad
Interested in one of my mods?
Old 01-03-2012, 09:58 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I'd like to hear TE's input on this.
Sean
Old 01-03-2012, 10:19 PM
brad12kx's Avatar
Rep:2581
You and me both! The last thing I want is a PCM that's programmed to destroy my trans!
BTW - I've got over 5K miles since the Sonnax, and my PCM still hasn't altered the shifts from when I first installed it. I sure hope this does NOT change, but it was going to, I'd have expected the change by now.
BTW - I do know the PCM is adaptive, as when I drive hard and manual shift, the trans pressure does increase, and shifts get even firmer. But they did that before anyway, as without the Sonnax, I was able to improve the shifting simply through aggressive driving to level the Sonnax gives at normal driving. Now when it improves, the shifts are very firm....not enough to chirp the tires, but enough to break them loose on slippery roads, something it WILL NOT do without the Sonnax.
brad
Old 01-03-2012, 11:23 PM
BlackHemI's Avatar
Rep:296
I think this.is my next.mod.then because I drive mind hard
-Pat-
Old 01-04-2012, 05:40 AM
2010 ram 2010 ram is offline
Vehicle: 2013 Ram CrewCab 1500 4x4 8spd
Trim Level: SLT Longstar
2010 ram is on a distinguished road
Just ordered mine from trans parts USA can't wait to put it on
Old 01-04-2012, 07:26 AM
09nitetrain 09nitetrain is offline
Vehicle: 2006 raqm 1500 trx4 hemi
Trim Level: trx4
Color: blue
Rep:20
09nitetrain is on a distinguished road
ordered mine last night along with a cold air intake and diablo sport tuner. next in the spring will be lift and exhaust
Old 01-04-2012, 08:56 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
It's so cheap and simple! Mine has been serving me well! I had a good 1-2 upshift this morning passing an 18-wheeler. Chirped @ 60!
Old 01-04-2012, 09:41 AM
snrusnak's Avatar
Rep:1385
Holy crap and I thought my first gear was loooooong, LOL! I forgot you had 3.21.
Sean
Old 01-04-2012, 10:09 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Got one in mine and i dont notice any difference at all
sonnax pressure booster
Sonnax Line Pressure Booster? JasonK94Z 5.7L (345 cu in) HEMI V8 Specific Topics 11 09-10-2011 07:57 AM
Sonnax Electric Line Pressure Boost Pull Ya 5.7L (345 cu in) HEMI V8 Specific Topics 5 05-13-2011 05:26 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Sonnax Line Pressure Booster and Jet Stream Scoop, Installed ScatPak07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 9 11-22-2010 05:26 PM
Sonnax Line Pressure Booster MotorCityRam 5.7L (345 cu in) HEMI V8 Specific Topics 5 02-25-2010 09:47 PM
