tonneaucovered.com
Old 09-23-2011, 07:03 PM
Thedome Thedome is offline
Vehicle: 2008 Dodge Ram 4x4 Sport
Thedome is on a distinguished road
Default 2008 35 inch tire question
Will a 35 fit on my 08...Truck is lifted/leveled with rear blocks. I want to use an 18x9 wheel with a 4.96 backspacing with a 35x12 tire....will they fit/rub without a spacer?? Thanks for your help and yes i tried search!
Old 09-24-2011, 03:10 AM
unrealtrip's Avatar
unrealtrip unrealtrip is offline
Vehicle: 2008 Ram Big Horn 4x4
Rep:27
unrealtrip is on a distinguished road
How much offset on the tires? How much lift?
I have 35x12.5"s on 17x9 0mm offset 5" backspaced wheels and at full lock I just barely rubbed the bottom edge of the plastic wheel well liner, so using a heat gun I pulled it out and no problem. I have a 2.5" Daystar "lift" using spacers up front, blocks in back.
I've got a shotgun a rifle and a four wheel drive...
Old 09-24-2011, 12:31 PM
I have the same questions about the wheel offset and the size of your lift.
I have a 4" lift, an 18X9 wheel with a +18 offset and am running a 285/75 tire (35X11.5) and I have no rubs.
Last edited by erm; 09-24-2011 at 05:03 PM. Reason: 'cause I wasn't clear at first...
Old 09-24-2011, 02:01 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Maddog my buddy has an 06 2500 with a 2" level with 17x9wheels with 5" backspace and +0 offset with 305/75/17 and doesn't have any rubbing
Old 11-10-2011, 06:11 PM
K my 35's are on...no rubbing at all =) pics to come!
Old 11-16-2011, 03:55 PM
2011 ASSAULT 800's Avatar
Trim Level: Quad Cab Sport
Rep:251
awesome! lets see some pics!!
95 v10 4x4 lift and tire question twistedfate87 Suspension 0 03-12-2011 05:15 PM
Dont punch me in the face please tire size question Gladi8r Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-09-2011 12:55 AM
Suspension Lift/Rim and Tire Question Hellspawn1 Dodge Ram General Discussion 2 03-02-2011 12:07 PM
2004 Ram 4X4 Tire Fit Question???????? 04ram4X4 Dodge Ram Wheels And Tires 4 06-29-2010 10:32 AM
Tire Question 03 Hemi Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 01-21-2010 10:38 AM
