Back from the track... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 09-23-2011, 10:24 PM
RTBenny RTBenny is offline
Vehicle: 2012 Ram R/T
RTBenny is on a distinguished road
Default Back from the track...
Not quite as disapointed here. The truck was super consistent (14.60s every run) and given that the track wasn't too good, I don't feel bad. I got the Titan beat at least! Here's the best pass:
2.157-60 foot
9.349@76.62-1/8th mile
14.602@@92.44-1/4 mile
Like I said, the Titan's best was a 14.9xx@91.04 and that was in cooler weather. It was 80* tonight when I ran and humid to boot (it is Georgia after all). Every run was from basically off idle or maybe stalled to like 1200 rpm. Anymore just smoked the tires. I know with traction I could launch a lot harder. I also thought the trap was a little low but these things fall on their face when they shift to fourth. I'm thinking that with a tuner I could raise the rev limiter to 6200 and it could run through the traps in third.
2013 F-150 King Ranch 4wd 5.0
Old 09-23-2011, 10:26 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Sounds like you did what you wanted and have a plan for the next steps. GOOOOO!
Old 09-23-2011, 10:35 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Nice times! You can get it DA corrected to see what it would be in "ideal" conditions on dragtimes.com if your interested. I can't even wind through 2nd gear with my 3.55's! lol....I need tiny tires!!!
Good job
(still pretty impressed to be honest with the titan...)
Sean
Old 09-23-2011, 10:54 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
some good baseline! what if you don't let it shift into 4th?
Old 09-24-2011, 12:20 AM
Nice runs! Try staying in third on a run or two and see if it helps.
Old 09-24-2011, 12:21 AM
RedRam10- I'm ready for mods, this truck will be amongst the first running the DSP when it comes out I can assure you. Intake, exhaust, and tune are just waiting in the wings.
SNRUSNAK- DA corrected time is 14.182@95.24. Not bad for a bone stock truck with 750 miles. Thanks for leading me to Dragtimes.com. Oh, and I would never tell my buddy Parker this, but none of this detracts from his Titan. The fact that an extended cab, 4x4, leveled out on 285/70/17 BFG All-Terrains on Moto Metals, bolton pickup truck runs what it does it damn impressive.
CHVYKLR and MADDOG- I thought about trying that...after I had left the track. I can't see it helping really though. Third ends about 87-88 mph. The trap would really suck if I didn't let it shift that last time. But who knows?
The truck is going back to the track in two weeks with a few more miles, some new oil (who knows what kind of dinosaur excretion comes in new vehicles), and hopefully some cooler weather. Traction is still going to be the problem. I may pick up some 17" wheels and mount some 28 inch drag radials on them for the rear. That should get me traction and some extra effective gearing. My 4.10s would feel like 4.56s!
Old 09-24-2011, 08:12 AM
CHVYKLR's Avatar
Rep:252
Yeah, if you had a set of 28" tires it would def help your 4th gear problem as you'd top out somewhere in the 11X mph. And you'd prob end up with a mid to high 13 sec run!
snrusnak's Avatar
Rep:1388
Wow, now I'm really impressed with his truck! lol. I have NEVER seen a titan at the track that was even close to quck...
If you could hold your rpm's to 6,200(when the tuner comes out) you could stay in third through the gates(33" diameter tires right?). Smaller tires may help, and with slicks you'd gain some traction...but you'd also be shifting more, so it may not help as much as you'd think, but who know...to take advantage of gearing as much as possible you'd be better off with a really small tire(like lower to mid 20" diameter), to wind out 4th gear to take advantage of the high rpm hp. Problem is that small of a tire may not be feasable...
Sean
Old 09-24-2011, 10:58 AM
Yeah, one big advantage he has is the 4wd though. He ran a 16 flat in two wheel drive cause is just smokes one back tire. In 4wd though he can get decent sixty foot times (2.1x) and then since his redline is 6250 rpm, he runs the traps in 3rd (1.52:1).
Next time we go he's going to mount up his stock wheels and tires. They're a little lighter and slightly shorter. He may be even quicker! He's also looking in to header options and I've been trying to convince him that spray is way to go after that.
back pressure? creed0423 Exhaust 17 04-15-2011 02:41 AM
Just got ren and back up cam installed have a question Ray 2010 Dodge Ram Forum 7 03-10-2011 09:45 PM
So it is a posi track!! yamifz1 LD RAM - General Discussion 16 03-03-2011 05:50 PM
Bought a new truck a few months back and nothing but problems at first! heffs03mach1 2010 Dodge Ram Forum 8 02-03-2011 10:33 PM
Back In A Ram, New To The Forum 2010NebBigHorn Newbie Checkin! 10 01-04-2011 06:26 PM
