DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum SRT Viper Forum
Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram – 1994 to 2001 Dodge Ram Trucks > Electrical
Dodge Ram Accessories!
Old 09-24-2011, 12:55 AM
tekstrand24's Avatar
tekstrand24 tekstrand24 is offline
Vehicle: 1997 Dodge Ram
Trim Level: 1500
Color: Chestnut Brown
Rep:57
tekstrand24 will become famous soon enough
Default Antenna Removal
Anyone know how to remove the antenna to replace it?
RamForumz.com | Dodge Ram Forum | Dodge Ram Forums | Dodge Ram Performance | Dodge Ram Accessories | Custom Dodge Ram | Dodge Truck Forum | Ram Truck Forum
Old 09-24-2011, 12:56 AM
turn counter clockwise. If you have a slotted top cover, just get a pair of needle nose pliers, one tang in each slot and turn counter clockwise.
Old 09-24-2011, 02:43 PM
Trim Level: 1500
Rep:57
I took the slotted cover off but does the actual black part of the antenna just screw off?
Old 09-24-2011, 04:57 PM
Yes...it just screws in.
Old 10-07-2011, 08:27 PM
Ram BeaSST Ram BeaSST is offline
Vehicle: 1998 Dodge Ram SS/T
Trim Level: SS/T
Color: White with Blue Stripe
Ram BeaSST is on a distinguished road
just curious, what did you replace it with? aftermarket? i need to replace mine, too.
CAI, blue 8mm spark plug wire set, platinum spark plugs, 180* t-stat
Old 10-09-2011, 02:19 PM
Trim Level: 1500
Rep:57
I am replacing it with a short aftermarket antenna. With the lift I have the stock antenna hits the top of the garage and over time it has deteriorated so I had to replace it.
Old 01-28-2012, 01:59 PM
Trim Level: 1500
Rep:57
Does anyone know how to remove the entire antenna? Not just the part the unscrews but how to get to the wire?
Old 05-09-2012, 06:53 AM
bigreid's Avatar
bigreid bigreid is offline
Vehicle: 2011 Ram
Rep:23
bigreid is on a distinguished road
Thanks for this, I was unsure with the slotted tab
Old 08-15-2012, 08:33 AM
BobbyDukes BobbyDukes is offline
Vehicle: 2012 Ram 1500 Sport
BobbyDukes is on a distinguished road
Question
Hey guys, I have the chrome cap off, however the little black piece, which is obviousily attached to the antenna, wont see to budge? How much force should I use? So I vice grip on the black piece and turn counter clockwise??
Old 08-15-2012, 08:53 AM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
Look at the antenna mod here it may be a solution for you instead of installing a new antenna. Recycle
http://www.ramforumz.com/showthread....ntenna+removal
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Scanner Antenna Where Factory Antenna Is Located??? Ramathorne 2010 Dodge Ram Forum 2 03-12-2011 08:25 PM
2005 Antenna help benb70 Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 02-22-2011 12:37 AM
Antenna Help. CustomShirts Custom Dodge Ram Interior Modifications - Custom Audio / Video 18 09-16-2010 08:34 PM
Replacing stock antenna with small aftermarket antenna mast Rairwalk 2010 Dodge Ram Forum 27 09-14-2010 08:42 PM
Sirius Antenna rjs2005 Custom Dodge Ram Interior Modifications - Custom Audio / Video 11 02-11-2010 07:23 PM
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
