Old 03-11-2012, 11:14 PM
D Lyons D Lyons is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: Magnum
D Lyons is on a distinguished road
I just used it in my 98 5.2 and it ran like crap for almost a week, then it finally smoothed out. I've heard really good reviews on it but it didnt work for me.
Old 04-16-2012, 04:58 PM
Bearzigmoo Bearzigmoo is offline
Vehicle: 97 Dodge Ram 1500
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
Bearzigmoo is on a distinguished road
I heard a Qt. of deisel fuel , run about an hour. drain.
Old 05-07-2012, 04:06 PM
renegadex08 renegadex08 is offline
renegadex08 is on a distinguished road
Should I do the full seafoam method on an 09 Ram Hemi with 56000 miles or should I add the injector cleaner to the gas. Any info would be appreciated
Old 06-04-2012, 09:09 AM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 15 BigHorn Ecodiesel
Trim Level: Big Horn CC
Rep:225
namretsud has a spectacular aura aboutnamretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Seafoam is used as a fuel injector cleaner. Just pour the contents into the gas tank and let it run its course. Seafoam just has some alternate methods of doing other than the injector cleaning by following the instructions.
Old 07-14-2012, 08:46 AM
OklahomaHoss's Avatar
OklahomaHoss OklahomaHoss is offline
Vehicle: 1990 Ram LE
Trim Level: ?
Color: Black/Gray
OklahomaHoss is on a distinguished road
Originally Posted by sonocativo View Post
Well the can says so much in the gas, so much in the vacumm line and so much in the oil.... but thats stretching it a long way, I usually put almost 3/4 can in the gas and whats left in the vacumme line, then I put a small can in the oil ( you can buy seafoam in small and large cans but the large can isnt all that big anyway ) But for a big motor as our 360's I put a whole small can in and run a few days, If I was going to change it the same day I might put a large can in but I dont want to ruin a bearing or anything just want to clean the sludge out of the block and carbon off the pistons/valves/intake... If using a full large can I would change it the same day after running it awhile to clean it up... if using a small can you can run a few days to circulate and let it work its wonder, I wouldnt trust running a full big can in it more than a couple hours as it will thin the oil not to forget the crap that gets broke loose and floating in there ( the oil filter will catch most of the crud so it could clog as well ) after about 2 seafoam flushes the block will be pretty clean, then a regular flush with seafoam every once in awhile will keep it in tip top shape. There are other products out there that does the same thing it just depends on what you want to spend.
Years ago ( 40's, 50's, 60's ) guys used to add trans fluid to the oil as the high detergent will clean the blocks as well... I havent researched it but I have heard alot of old car guys at car shows talk of this... myself, I wouldnt, especially on newer cars as they arent made like those cast iron beasts back in the days.
Wait a minute...Are you guys saying it's actually safe to pour some SeaFoam (my buddy recommended this to me for the gas tank) into the actual crank case where I'd normally put a quart of oi, and then actully start and drive the engine for a day or two?
1990 Ram 150 LE
318 ci, Automatic tranny
Old 07-14-2012, 02:00 PM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
I used it in all my cars in the gas and.oil only one I run though the vacuum line.is my cobalt as to.clear out carbon build up. It really does seem to work
Old 07-14-2012, 09:10 PM
Canviper's Avatar
Canviper Canviper is offline
Vehicle: 2006 Dodge Ram SRT 10
Trim Level: SRT-10 Nightrunner
Rep:26
Canviper is on a distinguished road
A question for the Canadian guys. Where are you guys buying your Sea Foam at? I can't find any where I live in Central Alberta.
NIGHTRUNNER #167/#400 MODS: K&N CAI, BBK TB, BORLA EXHAUST catless, AMERICAN RACING HEADERS, SCT TUNED By Chris Jensen. My album is finally up come check out some pics.
Old 07-14-2012, 09:54 PM
02 Ram 02 Ram is offline
Vehicle: 2005 Dodge NSRT-4
Color: PX8
Rep:67
02 Ram will become famous soon enough
is it OK to dump a 16 ounce can in my 4.7L? was reading about oil sludge killing the 4.7L's and since i have 157K miles on my truck it doesnt seem like a bad idea to do anyway. just want to make sure its ok to use a whole 16 ounce can in the crank case. ill do it on my next oil change. i was thinkin, a whole can in the crank case, half or whole can in the vac line and one in the tank. how long should i let it idle? and lastly, whats the best vac line to use to suck it though? on my RT, i would use the brake booster line to hit all cylinders. new to this truck and V8's. ill probably put a whole can in the tank and fill up too soon. TIA guys
2005 Dodge NSRT-4
Old 07-17-2012, 09:34 AM
namretsud's Avatar
Rep:225
Crappy Tire and Car Quest both carry it. Others probably do as well. Just ask around.
