Old 09-24-2011, 11:32 AM
RAM1961 RAM1961 is offline
Vehicle: 2000 RAM 2500 V-10 Quad 4WD
Trim Level: SLT Laramie
Color: Maroon
RAM1961 is on a distinguished road
Default Low beams don't work, but high beams do?
Hi,
2000 RAM 2500 V-10 Xtra Cab. Came home last nite from dinner right at dusk, and noticed low beams weren't working. Went out and visually inspected - high beams worked but no low beams. So drove the backroads home to avoid issues.
Got home, shut the ignition off, then turned the headlights on. Both low beams worked fine, and switched fine between low and high beam. Turn the truck back on - low beams quit working, but as before high beams work. Fog lights work as they should - on with low beam, off with high beam whether truck is running or not.
So....is this the switch on the column, and if so, is it hard to change out?
Thanks in advance.
Old 09-29-2011, 11:31 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and I sure wish I had an answer for you. Best I can do is this back to the top for you.
Old 10-03-2011, 01:17 AM
DODGECUMMINSWOODY DODGECUMMINSWOODY is offline
Vehicle: 2001 2500 4x4
DODGECUMMINSWOODY is on a distinguished road
Thats an interesting one! I don't know if I have an answer for you , I'm trying to find a schematic. Are you sure its the switch on the column thats bad ?
Where Do You Work??? MADDOG Off Topic Discussion 441 05-13-2015 11:55 AM
wiring offroad lights to high beams hemitrx4 Electrical 7 03-15-2014 11:33 AM
HID high and low Amp211 Custom Dodge Ram Interior and Exterior Lighting 8 10-12-2013 08:03 PM
Lamp Out Indicator & High Beam Hesitation Black05 Electrical 2 07-17-2011 04:38 PM
High beam replacement bulbs 2011RamCC 2011 Dodge Ram Forum 4 04-25-2011 09:54 AM
