Old 10-16-2011, 02:53 AM
xPUNlSH3Rx's Avatar
xPUNlSH3Rx xPUNlSH3Rx is offline
Vehicle: 2005 Dodge Ram
Trim Level: SLT AWD
Rep:38
xPUNlSH3Rx is on a distinguished road
Update..I tried to start the car n there is no spark. It will crank over and I have fuel but the coils are not seeing spark.
Tomorrow I will check my ECU and see if the CAS is working, other than that I will try maybe the ignotor chip.
If you have any tips let me know
Performance: Flowmaster Super 44 Side Exit, MagnaFlow Y pipe and Spectre CAI
Audio: Pioneer AVH-P5200BT, MTX Thunder 6x9, JL 10" Sub, Audiostream BX-10 Bass processor, Jensen 500w Amp and Rockford Fosgate wiring
Old 10-17-2011, 01:36 AM
Inabj2 Inabj2 is offline
Vehicle: 2003 Ram 2500,90 Turbo 240sx.
Trim Level: SLT?
Inabj2 is on a distinguished road
I would check your ignitor first, cas second, then your harness, Rarely will the ECU go bad, I'd check that after all the others check out fine.
Old 10-17-2011, 09:03 PM
xPUNlSH3Rx's Avatar
Trim Level: SLT AWD
Rep:38
Yea, I'm checking all the cheaper parts first lol...I got a video of it check it out
Watching the video it really sounds like it tried to, so it might not even be the spark. Any ideas? I did and Ohm test on the injectors and they tested good. Tonight I will check the ignitor and make sure my wiring on the 2 plugs near the battery are good too.
Old 10-18-2011, 02:11 AM
Trim Level: SLT?
How did you confirm you did not have spark?
Car will not fire, not even for a millisecond without spark. At least some of your cylinders are getting spark...
If you got gas, and you got spark, Id check timing is set properly.
If you are missing spark in only 1 or 2 cylinders, I would check the pins in your ignitor ship are not bent or broken. One time I did not have spark on cyl 2 because somehow the pin for that cylinder got bent and did not plug into the harness. After that checks out I would then move on and check your harness wiring. Also ensure its properly grounded, too, all kinds of weird crap happens when its not.
If ignition for all 4 cylinders checks out then your timing could be WAY off, Set cylinders TDC and ensure the timing chain marks match the cam sprockets, and its time to take out your cas and install it in properly. Check the FSM that is all over google to see how to do that....
Or just click here:
http://www.phase2motortrend.com/nifasemaf.html
Old 10-18-2011, 03:55 PM
xPUNlSH3Rx's Avatar
Trim Level: SLT AWD
Rep:38
Well my friend that helped me do the swap said he took care of the grounds but apparently the motor wasn't even grounded, so I took care of that last night and the injectors Ohm check came out ok.
The way we did a spark check is we took the coil out, plugged a spark plug to it and touched the side of the plug to the valve cover but it wasn't grounded at all so we didn't see spark :/
Ill verify the pins on the ignitor tonight, and as for the timing when I bought the motor I took the valve cover off, chain sprockets checked, Cylinders TDC checked by needle on the second mark of the crank pulley, and CAS the both marks were aligned.
I really think my issue is the motor not being grounded properly, so this weekend I will finish up the e-fan wiring and give it another go
Old 10-22-2011, 01:26 AM
xPUNlSH3Rx's Avatar
Trim Level: SLT AWD
Rep:38
The beast runs!!! I am so excited. Had some grounding issues, adjusted the throttle body a bit and she fired right up. Sounds mean, I will post a video shortly
Old 10-22-2011, 02:32 PM
xPUNlSH3Rx's Avatar
Trim Level: SLT AWD
Rep:38
Old 10-24-2011, 04:07 AM
Trim Level: SLT?
That ticking sounds like you have an exhaust leak possibly by the manifold. Car will run but you will lose power and spool until its resolved. Take this with a grain a salt since I am basing this from a grainy video from my crappy laptop. But I would definitively (carefully don't get burned!), place your hand around the exhaust manifold and turbo and see if you feel any puffs of air at idle, it should be noticeable right away as soon as it fires. Also it should be able to hold idle steadily, are all 4 firing as they should? Or is the maf disconnected?
But a proper sr20det sounds like a mild mannered Sentra at idle unfortunately, until the wastegate opens up and it transforms from mild mannered 4 cyl sound to angry race car engine sound at full boost/ throttle. It shouldn't sound "mean" off idle, even with open header, (its just louder with exhaust off) I have the same cams as you do, and it should still idle smooth.
Old 10-24-2011, 08:40 PM
xPUNlSH3Rx's Avatar
Trim Level: SLT AWD
Rep:38
Here's the second time I ran it..MAF is plugged in, we got spark on all fours and all injectors are spraying, we checked this by taking the rail out and used a towel to see if they were spraying.
I will have to check for exhaust leaks on the manifold the next time I run it, but as for the idle we did a 3rd run after this after adjusting the screw on the throttle body and it held 900-1k rpm steadily for a good 2 minutes and after it was warm it climbed a little?
About the cams I heard when they are fresh out of the box they are pretty aggressive like a 272 but then they get a little better after a few miles in them, is this true?
Anyways I am happy it "sounds" ok to me and it starts within a second I turn the key
240sx, nissan, sr20det, turbo
1995 Ram 1500 Custom 12" Underseat Subwoofer Enclosure Build Studdlygoof Custom Dodge Ram Interior Modifications - Custom Audio / Video 23 08-23-2014 11:58 AM
My build sheet... Mopar44064268 Dodge Ram SS/T - Indy 4 06-29-2011 12:29 PM
Just Got My Build Sheet highlandchef 2009 Dodge Ram Forum 11 05-24-2011 06:12 PM
2012 Nissan Titan really a Ram in sheep (cheap) skin? cyberpine Other Vehicle Discussion 2 05-11-2011 07:00 PM
Hi, I'm new to the forum and am looking for a build sheet rpsklein Newbie Checkin! 19 08-30-2010 10:38 AM
