older trucks - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-24-2011, 04:02 PM
Color: MAXIMUM STEEL
Rep:801
Default older trucks
just wondering, since i have owned trucks with 350 engines, from a 1970 up to the 1990s, i'm pretty sure sure thay all took 4 quarts of oil. how come we are up to seven quarts. is this how they got away from the 3000 mile oil change to todays extended drain intervals or is there another reason. just wondering.
Old 09-24-2011, 04:10 PM
Rep:1388
I've never owned a v8 old or new that didn't take at least 5 qts. Most small 4 cylinders and some 6 cylinders take 4 qts. More fluid allows the fluid to stay a little cooler, and it doesn't break down as fast or get as contaminated as fast. So yes it helps with longer intervals...but is not the only reason for this. Some engines are just weird too, as my ford 300 inline 6 took 7.5 qts if I remember correctly...
Old 09-24-2011, 04:30 PM
5 quarts with a filter is what they took.
Engines are built to tighter tolerances today, generate a bit more heat and need the additional lubrication capacity to circulate more oil to the areas that need it.
Old 09-25-2011, 10:02 AM
pall2509 pall2509 is offline
Vehicle: 2001 Dodge Ram
pall2509 is on a distinguished road
yes, 5 quarts with filter on old 350's
Any Lowered Trucks On Here? RaiderJay6 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 286 11-14-2012 10:47 PM
Kinda new to Dodge Trucks KillerBBBs Newbie Checkin! 9 11-22-2010 10:43 AM
Convoi of 40 pick-up trucks jankee Dodge Ram Videos 8 09-28-2010 11:40 PM
New to trucks. Looking to get better performance out of my motor aaron201 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 3 09-03-2010 03:01 AM
Trucks episode? cowboytruckn Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 1 11-12-2008 11:45 AM
