Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 09-24-2011, 08:12 PM
hemiguy71 hemiguy71 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Crew Cab SLT
Color: Stone White
Rep:23
hemiguy71 is on a distinguished road
Default trying to figure out if my big horn 5.7 has limited slip?
Anyone know how to tell if your rear diff is limited slip, what to change fluid to synthetic and need to know because limited slip needs additive.
Old 09-24-2011, 09:52 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
There are a couple of ways that I know of to check for a LSD. The first one is to jack up the rear end, place the tranny in neutral then spin one of the rear tires. If the wheels spin in opposite directions then you do NOT have a LSD, if they spin in the same direction then you DO have a LSD.
Another method is actually easier, a lot more fun, but also probably not as accurate. (I'm sure that someone will jump in and correct me if I'm wrong here). Find yourself a dirt road somewhere, or even a stretch of non dirt road that has some dirt on it. Make sure that both of your rear tires are securely in the dirt. Stomp the gas pedal to the floor, holding it there for a few seconds. This should cause your rear tires to break loose. After going for a few feet come to a gentle stop, then walk back and inspect the skid marks (or the holes that you may have dug in the dirt). If there is one hole/ skid mark then you do NOT have a LSD, if there are two holes/ skid marks then you probably DO have a LSD.
You could also get a build sheet from your dealer. That should tell you as well.
good luck
Exco
Bill
Old 09-24-2011, 10:02 PM
Rep:2657
by the way, your transmission & rear end already have synthetic fluid in it, from the factory
Old 09-24-2011, 10:15 PM
Color: Stone White
Rep:23
Default oh did not know that.
I have 25,000 miles I figured would change anyway as will be hauling some weight this winter.
Old 09-24-2011, 11:31 PM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
Easiest way is to do a burnout. 2 lines, limited slip; one line, no limited slip
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 09-24-2011, 11:49 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Take your VIN to your dealer and have them look it up.
My 2010 has 3.55 gears, open rear diff and can light up both tires easily for 20'+ ... just sayin'
pic's from last May...
and that's spinning Heavy A$$ 305/50R20 Terra Grapplers on 20's (90lbs ea)
Old 09-26-2011, 11:23 AM
LUBINATOR's Avatar
LUBINATOR LUBINATOR is offline
Richie
Vehicle: 2009 Ram 1500 SLT Quad Cab
Color: Inferno Red
Rep:12
LUBINATOR is on a distinguished road
Default Very Weird
That is highly unusual. Never seen any open rear put power to both wheels like that and leave that long of rubber on road.
I have an old 454 engine in a 1972 chevy pick up with an open rear, suppossedly over 460hp. it will not power both wheels with an open rear diff and leave 2 equal skid marks. Both wheels can only get equal power with Real Posi or Limited Slip in any setup. Unless there is something different with your setup I am not familiar with.
We tried it with both our 2009 5.7 4x4s and both left only one skid mark. the 5.7 with the towing package, and LSD left two skids.
Unusual
RAM 1500 SLT QC 2009 INFERNO RED, ARE Lift Lid ,Spray on Bed Liner, K&N Drop In, Pioneer DEH P8400UB, Alpine Amp, Mopar Kicker sets in all doors and dash, 2 Polk 10" Subs, Polk AMP, SteelCraft Nerf Bars, Mopar Fog Lights, CalTrend Seat Covers, WeatherTech Front Mats, Putco SS Fender Liners, SuperBumper SS Hitch Step/Impact Absorber, Onki Aegis SS Center Guard, PIAA 2100 driving lights
Old 09-26-2011, 11:30 AM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
Do the 4th gens have a sticker in the glovebox that tells you? The sticken in my 3rd gen says right on it 3.92 with the LSD.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 09-27-2011, 09:23 AM
Rep:554
Unusual
Even in an open diff,
Power to Both wheels is Equal "if" traction on both tires is equal.
I'll admit it takes more power than stock and a setting on my Diablo Trinity to disable traction control (ESP)
are certainly factors in getting a decent dual wheel peel out of an open diff. It certainly doesnt do it all the time
But proving that it is possible pokes holes in the theory that only an LSD can pull it off for the purpose of identifying a LSD.
Cant really do a decent full donut with the factory ESP giving you a buzz kill half way through a 360º. Works great with Diablo disable though (open or LSD)
A better road test for an open diff is: right rear tire in the dirt/gravel on the shoulder of the road and the left rear tire (drivers side) on clean dry pavement,
Punch it and only the tire in the dirt will spin, and there will be no black mark on the pavement at the left side tire
Old 09-29-2011, 09:18 PM
cheesenr7 cheesenr7 is offline
Vehicle: 2009 Dodge Ram Sport
cheesenr7 is on a distinguished road
Correct me if im wrong but im pretty sure if you jack the truck up and put it in netural and spin the tires if you have a lsd one tire spins one way the other tire spins the other way. on and open rear end the other tire will barley move, then on a true posi or locker both tires will spin equally in the same direction.
My Build Sheet, Do I have Limited Slip Diff al2ride 4.7L PowerTech V8 Specific Topics 7 11-03-2011 10:35 PM
K36 Recall and 3.92 Limited Slip MrPEZO 2011 Dodge Ram Forum 1 06-07-2011 08:32 PM
Limited Slip question ddenton 5.9L V8 Specific Topics 4 05-25-2011 12:45 PM
Adding limited slip user zero 5.2L V8 Specific Topics 7 03-29-2010 11:46 AM
Limited slip trluby Newbie Checkin! 9 01-26-2010 09:46 PM
