Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 09-24-2011, 09:58 PM
Wayland Wayland is offline
Vehicle: 2005 Ram 2500 Diesel Quadcab
Color: Maroon
Wayland is on a distinguished road
Default Head scratcher PCM???
2001 Ram 1500 V6 starts right up after clearing computer runs correctly no codes or lights runs fine for any length of time. Shut it off. Restart 5 minutes later, check engine light on and code checker indicates incomplete monitoring of engine systems and internal pcm failure. Clear codes works fine again until you shut it off. I know just leave it run...... I bought this as a fixer upper and am not sure it has the right computer to start with. Ideas??? Thanks
Old 09-26-2011, 12:18 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
My guess is that you've got a corrosion problem, and it ain't gonna get any better without intervention. I would look at the ECU, pull its plug and inspect the contacts, on my truck that I had a bit of trouble with a few years ago, a 95 with a body lift, the ecu was catching salt spray off the rt front wheel, and it had to be cleaned up and greased up with antioxidant grease. I then bagged the ecu and sealed it with emblem adhesive tape (it was handy) an all plastic duct tape would do the same thing, sort of. I wish you luck!!
Chevys Head to Head Ben616 Dodge Ram General Discussion 2 06-05-2011 09:06 PM
Head gaskets or what? Hollywoodgt Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 3 11-02-2010 11:52 AM
'08 Ram Digital A/C control head txwooley Custom Dodge Ram Interior Modifications - Custom Audio / Video 7 05-08-2010 07:06 PM
Tailgate Ram Head Big Daddy Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 15 03-17-2010 06:35 AM
Head Units for 97 Ram 1500 atvredneck13 Custom Dodge Ram Interior Modifications - Custom Audio / Video 11 01-13-2010 05:59 PM
