Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
United Radio
Old 09-24-2011, 10:56 PM
mattee's Avatar
mattee mattee is offline
Vehicle: 2002 1500 Ram QC 4x4
Rep:13
mattee is on a distinguished road
Default front axle shaft
I have a 2002 4x4 and i'm trying to remove the front drivers side axle shaft. I already have the cv shaft out and I'm trying to pull the the axle from the differential and it will not come out. All the information I have says it is held in with a snap ring just like the cv shaft is and it should come out with a slide hammer but mine will not. Is there a secret to this that I just don't know? Any help would be great. Also if anyone knows of any videos out there that would be great too.
Thanks
Old 09-30-2011, 12:26 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and I sure wish I had an answer for you. Best I can do is this back to the top for you.
Old 10-01-2011, 09:57 PM
mattee's Avatar
Rep:13
Thanks, I did finally get it out. It would not come out the way it was supposed to so I took the differential cover cover off, pulled the center pin and pushed the axle shaft into the differential. Once I did that I just pulled the clip off the axle and slid it out. All new parts are installed and i'm back on the road.
Old 10-08-2011, 06:27 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
I'm curious, what all were you replacing? My front drive shafts are apparently bad. Did they look like this?
Old 10-13-2011, 05:30 PM
mattee's Avatar
Rep:13
Sorry, I havn't been on the site for a while. Looking at your info you the exact same truck as me. I replaced the CV shaft and Axle shaft on the drivers side. The reason I replaced them was becuase the shaft splines were rusted away. What makes you think yours are bad, you usually only have to replace them if the CV boots tear and sling grease everwhere. It's not hard to replace just the CV shaft but the axle can be a little more involved. let me know and I can give the information you need.
Old 12-10-2013, 07:31 PM
cmonroe9709 cmonroe9709 is offline
Vehicle: 2003 Dodge Ram, 1500
Trim Level: double cab
Color: grey
cmonroe9709 is on a distinguished road
Hi Matte -- I am having this issue. I have the cover off. How do I get the center pin out to push it in?
2009 2500 Front Shaft Lube 09trk4me Newbie Checkin! 14 10-30-2011 11:19 PM
snapped front axle H22A1 Dodge Ram Warranty Issues 4 05-31-2011 04:58 PM
leaking oil from front axle roundtownram Dodge Ram 4x4 - Offroad Discussion 2 04-29-2011 06:04 AM
1996 dodge ram front axle 96RAMMAN Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 2 03-15-2011 04:33 PM
Death wobble = axle swap fundaddy75 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 11-08-2010 11:50 PM
