Old 09-27-2011, 06:33 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Originally Posted by BadHazard View Post
they are 31" Its adjusted.
Damn this sucks lol. Ill give it a try on stock later and see what my times are.
I don't know if this would affect your times, but you should not have had to adjust your tire size in the tuning especially if they are stock tires. SC tire size will read around 30.0 or 30.5 for 31.5" tires but what ever it is you should leave it at SC stock tire settings for factory size tires. edit: Same goes for your ring gear, leave it at the factory settings if it is indeed the gear that came with it. I can't see anything that would affect your times that bad other than a misscalculation somewhere, hopefully this is causing it. That's just a hunch, good luck!
Old 09-27-2011, 07:45 PM
BadHazard's Avatar
BadHazard BadHazard is offline
Vehicle: 2006 QCSB, 1500
Color: Inferno Red
BadHazard is on a distinguished road
i see what you're saying, but what is the explanation of the slow as heck stock times?
06 QCSB, 1500, Laramie, 4x4 50k. 18" Rockstars, K&N Drop in Filter, Muffler Delete, SuperChip
Old 09-27-2011, 08:01 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
are your tires the same size as stock? if they are a different size then you would have to adjust for them....right?
Sean
johnnyG's Avatar
johnnyG johnnyG is offline
Vehicle: 2004 Dodge Ram
Trim Level: Hemi Sport
Rep:34
johnnyG is on a distinguished road
the thing that led me to check all those things was that my truck was approaching its 90k and my mileage was getting really bad, around 9 avg. i would drive another ram same year and feel a bit of a difference. i never recorded any times but i do know that after i got everything cleaned up changed and installed the CAI, muff and Y i could chirp those tires without trying. i never used to be able to get a good spin on dry pavement and now they scream in second gear if i open it up. i also just installed the sonnax line pressure booster and so far it is working out great. i really think you are going to get a lot out of the TB cleaning if it hasnt been done before.
SC 3865, K&N CAI, Fastman TB, Magnaflow Y to 18", sonnax, Zeon LTZs, Bilstein HDs, LEDs everywhere, sylvania ZXE heads and fogs, shorty antenna, all aftermarket audio and subs, linex, ez down tailgate and lots and lots of love.
Old 09-27-2011, 08:16 PM
ORT's Avatar
ORT ORT is offline
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
BadHazard, an email with the shift schedule has been sent your way. Let me know any questions or problems you have.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 09-27-2011, 09:54 PM
RadioFlyer's Avatar
Rep:146
Is this SC 0 to 60 times or from the race track? I'm assuming that SC calculations could be off in gear/tire size ratios causing miss calculations in times. You need to leave the gear ratio and tire size settings alone if they are stock. SC has your vin with the correct info with the correct settings. I'm just sugesting that you at least start from their stock gear and tire settings and go from there to eliminate that possibility. If my truck needed a tune up, I would know and hopefully you would with yours. So if it doesn't run bad, miss out or have any flat spots, I don't think even a tune up will result in an extra 2 sec off your time. That being said, any first to second shift schedule around 5950 to 6100 and second to third around 5950 to 6000 should result in much better time than what you are showing. Im at 6100 from first to second and 6000 from second to third which works fine for me. You should at least be at 6000 for first to second and 5950 for second to third and 6400 redline. If you are, no other shift schedule is going to help imo. It's very possible that your TB/intake is dirty and you need a tune up, but I don't think that alone would be enough...something seems wrong somewhere in SC settings. EDIT: It would help some if you had a freind with the same truck and tuner to race and match each others times to help resolve it. I'm just saying, are those times correct and is something wrong with your tuner? Have you physically checked to see if you have a 3.55 gear ratio...you did buy it used? What speed and rpm are you at when you shift to second? I'm at 58mph/6100rpms when shifting to second with 3.92 gears/31.5 tire height.
Old 09-28-2011, 12:31 AM
BadHazard's Avatar
Color: Inferno Red
I bought it used. I have 3.55 gears. My tires measure 31.5" tall. The stock SC is 30.25. The times are recorded via SC. I recently adjusted my shift points, we'll see if that will knock down some time. It seems like you can almost get to 60 in 1st. But in my case 3 seconds to get that extra 10mph. Ill pull the TB tomorrow and see what it looks like.
Old 09-28-2011, 05:34 AM
RadioFlyer's Avatar
Rep:146
Then 30.25 is where it is supposed to be and I hope that's where you have it. (that's where mine is set and I have 31.5 " tires too) Also, is it possible that ur timer is starting before you launch? The next time you do ur test run do not power brake it. Hold the brake with as little effort as you can without it moving and with as little rpms, say 900. You do not want ur tire to spin, it may trick the timer into starting before ur ready to launch. When ur ready to launch nail it and let off the brake right away. That is the best way to launch these trucks with stock converters. Power braking too high will confuse ur timing/pcm and slow ur reaction time. I know that may sound stupid or far fetched, I'm just trying to help.
Old 09-28-2011, 08:15 AM
snrusnak's Avatar
Rep:1385
^ yeah I think the computer pulls timing if you power brake and it will slow you down.
Radio: Why are you suggesting he not change the tire size? Am I missing something? Doesn't that change need to be accounted for?
Sean
Old 09-28-2011, 08:51 PM
BadHazard's Avatar
Color: Inferno Red
I know my transmission settings are working, Is it possible that the actual tune is not taking place? And maybe something is wrong with the tuner? And the difference in my times are due to different shifting points? Thoughts?
My TB wasnt that bad, I cleaned it all up tho.
Need help from owners with 4.7L and superchips snrusnak Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 17 10-04-2011 08:17 PM
Superchips 3715 Leadfootluke Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 3 05-25-2011 01:14 AM
Superchips results partymn Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 9 05-10-2011 11:19 PM
Superchips Review Adub Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 30 11-16-2010 10:59 PM
Superchips problem... need help asap live2ride 5.7L V8 Specific Topics 7 08-30-2009 12:19 AM
