Old 09-28-2011, 10:14 PM
BadHazard's Avatar
BadHazard BadHazard is offline
Vehicle: 2006 QCSB, 1500
Color: Inferno Red
BadHazard is on a distinguished road
Originally Posted by ORT View Post
Did you have the stock cats opened up to 3"? The stock cats are only 2.5" diameter inlet and outlet.
the cats still have the stock y pipe. the cats are 2.5 out
06 QCSB, 1500, Laramie, 4x4 50k. 18" Rockstars, K&N Drop in Filter, Muffler Delete, SuperChip
Old 09-28-2011, 11:36 PM
BadHazard's Avatar
Color: Inferno Red
I guess if I push hard enough it spins about 3 inches back and forth. The emergency brake wire that runs across the rear axle is slightly melted, side effect of when my exhaust fell off.
maybe my e-brake is slightly dragging? Any idea how to adjust it?
Old 09-29-2011, 08:01 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
So you can not spin the rear wheels while off the ground, with the parking brake(not e brake lol) off, and in neutral? Then yes something is wrong, it should spin freely. Sounds like you may need a new parking brake cable or something.
The 3" exhaust will not hurt anything. Any bigger would not be recommended though.
Sean
Old 09-29-2011, 03:58 PM
BadHazard's Avatar
Color: Inferno Red
well turns out the person helping me last night had their foot on the brakes, they thought i was seeing if it worked lol. My e-brake is fine, lol.
Old 09-29-2011, 04:04 PM
snrusnak's Avatar
Rep:1385
lol. check the fronts too. check all four corners and if they are all spinning free that eliminates any drag from brakes/bearings...
Sean
Old 09-29-2011, 05:03 PM
BadHazard's Avatar
Color: Inferno Red
is there a way to do a compression check? I know with the diesels you can hook a computer up to the injector to see if its flowing good. Wondering if there is any easy way other than pulling the plugs.
Old 09-29-2011, 05:05 PM
snrusnak's Avatar
Rep:1385
Gotta pull a plug on each cylinder to check compression...
Sean
Old 09-29-2011, 05:17 PM
BadHazard's Avatar
Color: Inferno Red
would there be a CEL or code if i had a dead/low cylinder?
Old 09-29-2011, 06:21 PM
snrusnak's Avatar
Rep:1385
I think it'd only throw a code if there was a bad coil/plug not firing/misfire situation. How many miles did you say it has? It may just need a tune up....bad plugs could cause poor running conditions...do you know of it's maintenance history?
Sean
Old 09-29-2011, 07:10 PM
BadHazard's Avatar
Color: Inferno Red
52k miles,..................
Need help from owners with 4.7L and superchips snrusnak Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 17 10-04-2011 08:17 PM
Superchips 3715 Leadfootluke Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 3 05-25-2011 01:14 AM
Superchips results partymn Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 9 05-10-2011 11:19 PM
Superchips Review Adub Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 30 11-16-2010 10:59 PM
Superchips problem... need help asap live2ride 5.7L V8 Specific Topics 7 08-30-2009 12:19 AM
