Old 09-25-2011, 04:16 AM
aparodox2003 aparodox2003 is offline
Vehicle: 2002 Dodge Ram
Trim Level: 1500 Sport
Color: grey
aparodox2003 is on a distinguished road
Angry Blower Motor Not Working :(
Im hoping somebody here can help we with this....My blower motor stopped working a few days ago, ive checked the motor itself (wired it to cigar lighter) so i know the motor works, i have about 11 volts going through the green feed wire, so i know its got power there, and ive already spent 50 bucks on a new resistor because i thought that was the only thing left and my old one showed signs of wear and had a hairline crack....so after that i checked for continuity in the wire leading to the control panel, it was brown with yellow i believe, it seemed good, and i bybassed the control knob jumping the brown wire directly to the black/blue wire leading to the ignition switch.....ANYBODY KNOW WHERE I CAN FIND THE OTHER END OF BLACK/BLUE WIRE FROM CONTROL PANEL OR DID I MISS SOMETHING???? I really dont want to take the rest of my dash apart unless i have too.....oh and i did check all the fuses and relays in the fuse box, but if there is an inline fuse or some other gizmo that i missed i would love to know its location. Thankyou for any help you can offer
I believe this truck was also part of the 2003 recall as there are some snipped wires and a green wire feeding under the carpeting if it helps
Solved the problem, traced the green power supply wire back to the ignition switch and all looked good in there, the wire feeding the power into the ignition switch to supply the blower motor was black/pink, pulled apart the main wire adapter going from the engine compartment to the cab and discovered some melted plastic and that the loose wire was barely making contact throught the adapter....cut and rerouted the wire around the adapter and it works great now
Old 09-30-2011, 12:26 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and I sure wish I had an answer for you. Best I can do is this back to the top for you.
blower, control panel, ignition, motor, resistor
Blower motor speed ShoreRider Heating & Cooling 2 09-22-2011 06:38 PM
Blower Motor Fix Dalton Heating & Cooling 3 08-23-2011 02:36 PM
Blower motor problems! Help IM HOT!!! M0PARMGNUM Heating & Cooling 4 05-14-2011 06:13 PM
AC blower problems mcline1968 Heating & Cooling 4 12-22-2010 11:34 AM
Blower motor resistor block SD60F Electrical 3 11-25-2009 06:59 PM
