Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 09-25-2011, 03:49 PM
hunter27h hunter27h is offline
Vehicle: 1997 dodge ram 2500
Color: white (partly)
hunter27h is on a distinguished road
Default no heat '97 2500
I have spent 3 hours today, reading, and going out and checking stuff on the truck, as I read about different items to look at.
Temperature goes to just past 200 on the guage, all of the vents appear to work as they should when switches in proper positions, on both ac and heat, defrost setting brings ac on, as it should.
Checked inlet to heater core, hot, outlet side cool, at operating temperature.
Does this system not have a hot water switch, valve, is it totally dependant on a "blend" door?
Does the coolant constantly flow through the heater core?
Does someone actually recommend CLR for cleaning the heater core?
Recommendations?
Old 09-27-2011, 04:45 PM
Default Glad you asked that question!
I can't believe this thread has been on here for three days, without someone with the experience or knowledge to answer the questions, and I have spent the time doing the thread search, if the answers are on this site, I haven't found them. So here are the answers, no there is not a water cutoff to the heater core, other than the thermostat, yes it is a constant flow through the heater core, and yes on the older trucks, you better take the time to do the flush. "back flush" the heater core, and clamp off the heater lines when you are flushing the rest of the system. I spent more time searching on here, far more than it took to do the actual work, and I found more support on other sites.
I have been totally amazed, so I hope someone else finds benefits from this.
Ben
2500 and 1500 Differences?? hotchiliram 2012 Dodge Ram Forum 13 08-19-2011 04:11 AM
1500 or 2500? PLEASE Help a New Member! bill440rt 2011 Dodge Ram Forum 34 07-03-2011 12:38 AM
Hood heat vents, false into functional on 2500 J Heavy 2010 Dodge Ram Forum 7 03-31-2010 12:48 AM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 12:50 PM
04.5 2500 heat issues CUMMINS MAN Electrical 1 12-06-2009 12:34 AM
