Place your Ad Here!
Old 09-25-2011, 05:38 PM
Rep:2890
Default MDS delete, could it be done?
I am curious, could the MDS actually be removed from the 1500s ??
The 1500 HEMI models have the MDS, the 2500 & heavier models use the identical engine & don't have the MDS.
Could someone just remove the MDS unit & bolt the stuff from a 2500 right in its place?
I don't believe it is a SMOG device, so no gov't agency could say it is illegal.
I don't believe it would light up any warning lights
I don't see how it could even Void your warranty, or they would have to void all the heavier Rams warranties
What are your thoughts ???
Old 09-25-2011, 05:39 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Hmm.... very interesting. I never thought about it like that. Sounds like it could be done.
Dillon-aka, The Little Kid
Old 09-25-2011, 06:32 PM
It's possible but you also need a 2500 PCM or find someone who can remove the MDS function from your PCM.
Old 09-25-2011, 06:51 PM
Rep:2890
Isn't the MDS function one of the things a Tuner shuts off ??
if you could just remove it, it couldn't engage, almost the same as what a tuner would do
Old 09-25-2011, 07:25 PM
robbennett83's Avatar
robbennett83 robbennett83 is offline
Vehicle: 2010 ram 1500 sport
Trim Level: sport qc 4x4
Color: mango tango
robbennett83 is on a distinguished road
just drive in tow haul mode.
Old 09-25-2011, 07:32 PM
Rep:2890
The transmission would not hold up long doing that
Say i was in El Paso Texas, 724 miles to San Diego, i usually do it in about 10 hours
The transmission would likely grenade about 1/2 way using tow/haul
Old 09-25-2011, 11:00 PM
Rep:3337
A programmer can diable the MDS in the PCM, and if you want to get rid of the mechanical features of the MDS, you need to replace the MDS lifters and Inertia sells a MDS lifter delete kit for $175. The MDS is not part of emissions, only for the fuel economy, but the warranty of the engine would be toast since it takes the stock engine out of its designed parameters; the 2500s are designed without MDS, so that's why they can get away without it.
Old 09-26-2011, 01:24 AM
Rep:2890
But every 5.7 HEMI has the exact same bolt holes & everything else is identical, it is just the 1500s have the MDS added to it
That is why i can't see why it can't be done
I read up a bit more on it, you would need to replace the heads with heads from the 2500 or heavier duty series
so you could only use the short block from the 1500s
Here i thought it would be a simple add on removal
Old 09-26-2011, 01:36 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
You could disconnect the wiring to the MDS solenoids (C140). It's a 6 pin connector with 5 wires at the back of the engine on the drivers side.
However, I'm sure the PCM monitors it, and will get all pissy if it's disconnected and throw codes for multiply failures. I guess you could measure the resistance of the solenoids and all the 4 resistors to the connector to trick the PCM.
brad
Interested in one of my mods?
Old 09-28-2011, 12:03 PM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
Allow me to further complicate and confuse things....
Don't forget the Challenger also has the available HEMI, the one coupled to the automatic tranny has MDS and is rated somewhere around 350HP, the one coupled to the manual tranny does NOT have MDS and is rated somewhere around 375HP... the HEMI in the Rams is rated at 390HP
where does the difference in horsepower come in? Is it all in the exhaust/ intake?
just thought I'd add my twenty cents worth
Exco
Bill
When the MDS Functions Per the Engineers RootBeer MDS 34 12-04-2013 07:58 AM
MDS engine into non-MDS car issues ehlersa MDS 3 02-02-2012 09:21 PM
RPM variation between MDS and MDS OFF Second Life 2011 Dodge Ram Forum 8 08-16-2011 03:10 PM
MDS my BUTT alharm1 2011 Dodge Ram Forum 11 05-16-2011 08:51 AM
CAI + MDS Rasping? jimbodean Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 8 05-20-2010 12:46 PM
