Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
tonneaucovered.com
Old 09-26-2011, 11:30 PM
wetcoastdude wetcoastdude is offline
Vehicle: 2006 Laremie Diesil
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Rep:126
wetcoastdude will become famous soon enoughwetcoastdude will become famous soon enough
Default Automatic Transmision issue HELP.
First off I looked for a section on transmision but could not find on so I hope this finds the right eyes reguardless of the location in this forum.
I have a 2006 2500 diesel laramie (automatic)and often tow a cargo trailer that weighs in total about 3000lbs.
Today on my way home from hunting in the mountains I encountered a shifting problem that I have never had before.
While I have never had problems passing cars or maintaining speed uphill(in the mountains)while towing because of this shifting thing today I could not.
Normally while going up hill the truck would shift up around 2500 rpm and have lots of power but today it would not shift up and was running into the redline on the rpms. when I backed of the pedal it would then shift but no power or shift back down to the high rpm. I could not maintain speed going up hill.
What is going on???
Old 09-27-2011, 01:33 AM
Rep:2731
I can't say for sure, but it may be in LIMP MODE, i believe you can temporarily get it back to running normally, by disconnecting the battery cable for a period of time & then reconnecting it
A better idea is to go to to a Auto Zone or some place else & getting the CODE reading & then having the code cleared & start fresh hopefully
Old 09-27-2011, 07:13 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Any lights on the dash? Sounds like a shift solenoid crapped out on ya.
US ARMY-RETIRED
2015 Ram 1500 Laramie Crew Cab 4x4. 50k Miles...LOADED...BF Goodrich Rugged Terrain T/A, Mufflex Muffler Delete, Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, TruXedo Roll-up Soft Tonneau, MaxMate Stainless Brush Guard, 10k Lumen 22" Solidex LED Bar, DZ Tailgate assist, Total Load Control, AVS Visors and Bug Shield, K&N Drop-In, XenonDepot 5000k HID Headlamps in projectors.
Old 09-27-2011, 08:38 PM
Rep:126
Had it at the shop today and a belt of some kind for 2nd gear is broken and I will be getting a new transmission. Second gear just wasn't working period.
Does this sound right?
What are my options.
is there a trany I should upgrade for my minor amount of towing?
Crap!!
Old 09-30-2011, 08:18 AM
CaptnC CaptnC is offline
Vehicle: 2004 Dodge Ram 2500 4X4
Trim Level: basic
Color: gray
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
CaptnC is on a distinguished road
My 2004 was doing something like that last year. I checked the air filter and it was trashed. The area where I deer hunt at has a 8 mile strech of dusty dirt road and the fine dust clogged the air filter pretty fast.
Old 10-01-2011, 06:34 PM
rdefayette's Avatar
rdefayette rdefayette is offline
Vehicle: '04, 2500 4x4,5.9 HO,Auto,QC
rdefayette is on a distinguished road
2nd gear band is what was broken.
Get in touch with goerend.com tell the what you use the truck for (be honest about future upgrades) let the set you up with what you need. Trans is gonna cost you a TON anyway spend a couple more $ and make it your LAST trans. There will NOT be much difference between a plain jane rebuild and a Goerend other than it'll last about 1000 times longer.
'04.5, 2500 HO, Auto, QCLB, 4x4, CAI, 4" ANSA, Smarty Jr, Airdog 100
Old 10-05-2011, 01:41 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:93
And when you do, be sure to invest in a little $20 part known as a heavy duty band strut. Much stronger that the OEM piece. Every time you shift up to second, or drop down that band, the kickdown band, is involved and it's a major player, as you have learned. Make them show you the broken parts.
Lazy/non-existent downshifts - anybody else with this issue? Turbovsix 2010 Dodge Ram Forum 18 05-20-2011 11:48 AM
Automatic Start Issue / Check Engine Light 07Ram 5.7L V8 Specific Topics 4 05-19-2011 06:46 PM
Automatic door lock / unlock feature.. mbehlok Dodge Ram General Discussion 9 04-26-2011 11:14 AM
1999 Dodge Ram 5.2l Automatic Reverse Issue kingme425 5.2L V8 Specific Topics 2 02-05-2011 08:13 PM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-13-2011 12:30 AM
