Old 09-26-2011, 08:10 PM
ramfam's Avatar
ramfam ramfam is online now
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Default Bad dash pad
I have 01 with the standard broken dash board. This thing has a hole in it you can loose a small child in. but not the point. I found a replacement dash from L M C. How hard is it to do? If anyone has done this? How hard is it? Tips or advice would be apprishated.
Family truck' ster see restoreation of big al's 82 http://i1152.photobucket.com/albums/p497/ramfam01/690d234c.jpg
Old 09-29-2011, 11:44 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and I sure wish I had an answer for you. Best I can do is this back to the top for you.
Old 10-01-2011, 11:29 AM
ramfam's Avatar
Trim Level: Base
Rep:21
this is what I mean by bad dash I know that this is common on gen2 rams. so if any body has tackled this I need to know if there are hidden bolts or clips? or how to get the passanger air bag out. or if I have to take it out at all.
Old 10-22-2011, 11:42 PM
Brad750's Avatar
Brad750 Brad750 is offline
Vehicle: 1997 Dodge Ram
Color: Blue and Silver
Rep:27
Brad750 is on a distinguished road
Did you get it swapped out? Was this part an OE replacement or one of those covers? My 97 is looking very similar to yours.
Old 10-25-2011, 02:04 PM
ramfam's Avatar
Trim Level: Base
Rep:21
No I have not yet. The one I want is a reproduction from lmc truck just under 170.$ that I don't have yet. just the dash carpet the truck came with. But it dose make me crazy to know whats under there.
Old 10-25-2011, 05:15 PM
97ram666 97ram666 is offline
Vehicle: 1997 Dodge Ram 1500
Color: white with silver trim
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
97ram666 is on a distinguished road
The dash on my '97, I can fit my dog in. Didn't know they cracked that bad. My Grand Am dash is warped to hell and back too. (that's $1,000 from the dealer). For what we pay for vehicles, u would expect a better interior.... O well, just gotta get another I guess.
Old 10-26-2011, 10:51 AM
ramfam's Avatar
Trim Level: Base
Rep:21
Well lmc truck has them. Hell next to the haynes manual that book is a must for parts. and as soon as I can afford the dash, replaced ill try to do a step by step if one is not avalable by then.
Old 10-28-2011, 01:03 PM
Dieselkiss's Avatar
Dieselkiss Dieselkiss is offline
Vehicle: 99 Ram 1500
Trim Level: ST - Very Base Model
Color: Red with grey
Rep:48
Dieselkiss is on a distinguished road
Default Air bag removal
I had to remove my airbag when I did some wiring work on my '99 so I could run looms.
I'm doing this from memory, but if I remember right....you need to remove your glove box then look up under and disconnect the wiring block for the bag (disconnect you battery first and be careful, you don't want that thing going off), then if you look up under there there are...I believe....two bolts....undo them then the pass. airbag should just pull out.
It's been over a year since I did this so my memory is a little hazy, but I seem to remember once I'd removed the glove box the air bag really wasn't that hard to get out.
Old 11-01-2011, 09:10 AM
ramfam's Avatar
Trim Level: Base
Rep:21
I figured as much. Ive done body and intirior work years ago but didn't have to mess with air bag but once and that was a side. Replaced window regular. Thanks for help!
Old 11-01-2011, 09:55 AM
About that airbag...before you unplug it, disconnect the battery negative cable and let it sit for at least 15 minutes. The airbag has capacitors in it and they need to discharge.
So do that first. Then get on with the rest of it.
I'll see what I have in my '99 FSM on how this thing is removed. I'm sure it's a lot of little clips and fasteners, etc...
How do you pull the dash out? v10madness433 Body & Interior 23 04-06-2013 04:02 PM
2nd Gen Junk dash solution (maybe) misterunlucky Body & Interior 16 12-24-2012 01:23 AM
1994 CTD Dash Replacement johnny0874 Body & Interior 15 04-09-2011 10:22 PM
97 1500 Dash Replaced! brewman Dodge Ram Knowledge Base 3 02-05-2011 01:41 AM
Dash removal. Dieselkiss Body & Interior 0 03-11-2010 08:57 AM
