ive got lights need help!!!!!!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-26-2011, 10:22 PM
cherry98 cherry98 is offline
Vehicle: 1998 Ram 1500 ext Cab
Trim Level: SLT LARAMIE
Color: silver pearl
cherry98 is on a distinguished road
Default ive got lights need help!!!!!!!
ive got three lights (ABS, BRAKE, SEAT BELT,) what could cause the lights to come in the parking brake is not on and the brake fluid is full. the only thing i can think of is that there is a "click" and a "whine" coming from either the front or the back brakes but the lights were coming on a few months before the noises also i had to replace both rear brake cylinders but i did bleed the brakes im not sure if they are all related but please help any suggestions will be greatly appreciated thanks
stock (for now) silver 98 1500 4x4
stock (for now) white 06 1500 mega cab 2wd
Old 09-27-2011, 12:26 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
If you have hubs with built in ABS sensors there is one going bad ( had to replace one on my wifes van) only other reason would be the airbag is faulty ( had that problem on some work vehicles ) or the seatbelt sensor plug came loose. I dont know for sure but sometimes the proportioning valve will go bad as well and cause this. Have you tried to pull any codes ( local auto parts stores will check it for free )
I Am Groot !
Old 09-27-2011, 11:00 PM
Color: silver pearl
i have not tried to pull the codes yet but i will as soon as i fix the flat lol
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 18 06-09-2017 09:33 AM
2010 Ram Aux Lights dozier68 Custom Dodge Ram Interior and Exterior Lighting 7 08-30-2011 04:13 PM
just gauge lights and dome lights ohmega07 Electrical 4 05-05-2011 11:45 AM
Installed cab lights now no parking lights on right side MikeEB76 LD RAM - General Discussion 1 02-18-2011 11:26 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 02:33 PM
