Old 09-27-2011, 09:11 AM
jmmay82 jmmay82 is offline
Vehicle: 2000 dodge ram 2500 4x4
Color: blue
jmmay82 is on a distinguished road
Default 5.9 crank no start please help
2000 5.9 4x4 2500 It cranks strong has good fuel pressure at the rail just doesn't start. I have replaced the coil and the cap and rotor please help looking for testing procedures and a place to start it has no codes
Any help would be greatly appreciated
Thanks Jason
Old 09-27-2011, 12:17 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:215
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
are you getting spark at the plugs? yes? then try some starting fluid does it fire? No? then your injectors are not getting signal. Have you checked all fuses/relays? That where I would start... Maybe someone here that knows a little more or had the same problem will chime in soon. Hope this helps and Good luck.
Mike
Old 09-27-2011, 07:43 PM
JaM Customs JaM Customs is offline
Vehicle: 2001 dodge ram 2500
Color: blue
JaM Customs is on a distinguished road
crankshaft positioning sensor. gauranteed
Old 09-28-2011, 10:31 AM
Color: blue
thanks for the help it has no spark how woudl I test the crank sensor thanks for your help
Old 09-29-2011, 12:58 AM
Color: blue
honestly dont test it. just replace it. its a wear item. mine has gone out twice in 90k miles. takes 20 minutes to change. when the cps goes bad the comuter does not know where the crank is positioned obviously and does not know who or where is top dead center. not knowing where top dead center is it does not know when to fire the spark plugs. therefor it wont. giving you no spark...
Old 09-30-2011, 01:32 PM
Color: blue
Changed crank sensor standard brand form lee auto parts
Old 09-30-2011, 01:33 PM
Color: blue
still doesn't start any other Ideas ?
Old 09-30-2011, 08:17 PM
Color: blue
ok thats weird, i would have bet money that that was the problem. also check your coil pack. ive had to replace mine a few times also cuz salt gets in between the stupid plates its made of and corrodes it.
Tip Start Glow time seems forever CBR Dude 2011 Dodge Ram Forum 5 09-27-2011 09:08 PM
Truck will crank but won't start DougDoug 5.9L V8 Specific Topics 17 07-12-2011 10:57 PM
No crank no start ????????? rampage63 5.2L V8 Specific Topics 2 07-08-2011 02:38 PM
96 wont crank over or start 96blacky Electrical 3 07-08-2011 08:17 AM
2003 dodge ram wont start on 1st crank jgraybill 3.7L PowerTech V6 Specific Topics 1 01-09-2011 04:38 PM
