Old 10-06-2011, 02:00 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
im running 91 in mine and lovvvvvve it with the 91 tune
Old 10-06-2011, 03:47 PM
charcoal5.9ram charcoal5.9ram is offline
Vehicle: 2002 Dodge Ram
Trim Level: sport
Color: graphite metallic
charcoal5.9ram is on a distinguished road
ok, after looking into the symptoms of a blown plenum gasket, I've come to the conclusion that is what my problem is.
excessive oil usage---yes (was wondering where it was going!!!!)
pinging--------------yes
decreasing fuel mileage--yes (it was always bad, but seems worst than before hahaha)
sometimes bumpy idle--yes
so, looks as though I will have to fix this before picking up a bigger throttle body. time to place an order at hughesengines.com
Old 10-16-2011, 01:06 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
New O2 sensors will stop the pinging.
Old 10-20-2011, 10:35 PM
WhiteLightning98 WhiteLightning98 is offline
Vehicle: 1998 Dodge Ram 1500 SS/T
Trim Level: SS/T
Color: White/Blue Stripes
WhiteLightning98 is on a distinguished road
My SS/T's been on both 93 and 87 for extended periods and i have not seen any performance increase.
Old 12-28-2011, 08:34 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
need 91 or else it would ping after porting out my heads and intake... Plus I deffenitly feel the diffrence from 87 to 91.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 12-28-2011, 08:58 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
It's likely the fuel. That engine was designed a long time ago, and fuel has constantly been getting worse since then.
Sean
Old 12-28-2011, 09:22 AM
RAMING IT's Avatar
Rep:65
Got it. So what if i put 87 with a bottle of octane booster? does that stuff really work? what if i put 91 with a bottle of octane booster? what then....
Old 12-28-2011, 11:15 AM
snrusnak's Avatar
Rep:1385
It's probably cheaper and easier to just buy the higher octane. Plus you don't really know how much octane booster you'd need to add...
Sean
Old 12-30-2011, 04:55 PM
harleyrhdr harleyrhdr is offline
Vehicle: 2000 dodge ram 1500
Trim Level: laramie
Color: silver
harleyrhdr is on a distinguished road
ive always run 89. i have cat back flowmaster 2 1/2 exhaust, did the plenum kit, cold air intake, headers, waiting on the tuner from hemifever to get here. no pinging havent tried 87
Old 07-30-2012, 10:07 AM
Trim Level: sport
well its been a while, but I finally installed the hughes belly pan and gasket this weekend, while I was at it I also did, plugs, wires, cap, rotor, thermostat, upper rad hose, bypass hose, valve cover gaskets, replaced a couple vacuum hoses that were cracked, pcv valve, and an oil change. So I'm running 87 now and the pinging seems to be gone, and the bumpy idle is gone. but I just noticed yesterday that now around 1500 rpm there is a slight stutter if I take off slow from a dead stop. She idles fine, If I rev it in park it doesn't stutter, or if I pork it from a stop it doesn't seem to do it. I need to replace an o2 sensor, would that make the truck stutter at low rpm? I also put autolite platinum plugs in, is that the problem? Now I'm reading that these motors only like copper plugs, is there truth to this? should I just go and blow $20 on a set of copper plugs and see if that makes a difference?
fuel octane and DSP tunes Schnitzer21 2010 Dodge Ram Forum 9 07-24-2011 06:13 PM
89 Octane??? ND RAM 2011 Dodge Ram Forum 16 06-26-2011 12:36 AM
diablo approved modification of 91 tune to run 89 octane??? Bighorn5.7 Diablo Predator Questions & Info! 6 05-29-2011 09:05 PM
89 Octane RocknMedic83 2010 Dodge Ram Forum 26 03-28-2011 12:04 PM
89 Octane DaKid Dodge Ram Detailing and General Maintenance Forum 22 03-08-2010 10:50 PM
