Old 09-27-2011, 03:55 PM
davedawe davedawe is offline
Vehicle: 1999 dodge ram 3500 318
Color: white van Roadtrek
davedawe is on a distinguished road
Default Antifreeze dripping
1999 3500 318 dodge ram van
anti freeze dripping rear of belt pulley, is this the water pump drive? difficult to replace water pump? Thanks
Old 09-27-2011, 04:23 PM
Rep:2657
If it is the water pump that is leaking, it is usually coming from the under side of the pump, there is a round hole located at the bottom of the shaft housing that the fan is bolted to.
I would disconnect the ground cable from the battery, before feeling around down there
Vans are a bit harder to work on
Probably the best way is to pull out the radiator to work on the water pump, even in a car or pickup
I would also check closely the hoses & belt(s), it may be the best time to replace them, a radiator flush could only be a good thing
antifreeze, which kind/brand??? got hemi Dodge Ram Detailing and General Maintenance Forum 12 12-08-2012 03:47 PM
randomly leaking antifreeze trentowens92 5.9L V8 Specific Topics 4 10-19-2011 11:10 AM
Serious Antifreeze smell sfcb 4.7L PowerTech V8 Specific Topics 4 07-07-2011 10:37 PM
Which Antifreeze Coolant To Use Dizzydan02 Dodge Ram Detailing and General Maintenance Forum 14 03-07-2010 03:01 PM
Smell Antifreeze on Start-up dodgeramowner2002 4.7L PowerTech V8 Specific Topics 1 05-20-2009 11:03 PM
