Old 09-27-2011, 04:12 PM
cyberpine cyberpine is offline
Vehicle: 2010 Dodge Ram Quad Cab Hemi
Rep:53
cyberpine will become famous soon enough
Default 18x9 -12mm offset with 33x12.5 tires on 4th Gen 2wd stock Dodge Ram 2009+
Anybody know if it's been done on 2009+ stock 2wd truck? Rubbing? Pics?
I figure it's negative enough to allow for the wider tire and 33 high should be fine. I don't want to level or lift.
Thanks.
http://www.cyberpine.com
2012 Red Ram 1500 Hemi Regular Cab.
** PLEASE HELP .. Can I run 18x9 -12mm offset 4.5 Backspacing with 325/60/18 on a stock (no lift no level) 2wd 4th Gen RAM w/o rubbing? PLS MSG ME!
Old 09-28-2011, 11:58 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
I would just be worried about being out that far and being that much wider and clipping fender edges of the wheel wells. Usually leveled trucks are safe at the +/- 0mm offset
2011 Big Horn 4x4 -SnowWhite-
-12mm offset GolfSIX Dodge Ram Wheels And Tires 3 09-20-2011 11:17 AM
Rain + stock tires = new tires tan brule Dodge Ram Wheels And Tires 7 08-13-2011 10:43 AM
Stock 20" Wheel Dimensions - offset backspacing Digipenguin Dodge Ram Wheels And Tires 2 10-04-2010 10:41 PM
17" wheels off for new dodge. DODGE4x4 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 11-25-2009 02:28 AM
Biggest Tires on stock '04 1500 Ram Eng0270 Dodge Ram Wheels And Tires 1 10-15-2009 11:57 PM
