Whining/Banging rear end, leaking fluid from Driveshaft/rear end joint. Help! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-27-2011, 07:52 PM
OoMesKoO OoMesKoO is offline
Vehicle: 2000 Ext. Cab Ram Sport
OoMesKoO is on a distinguished road
Default Whining/Banging rear end, leaking fluid from Driveshaft/rear end joint. Help!
Hey guys.
I am having a problem... I noticed that there was a strong whining noise on a ride home tonight, and it continuiously got louder. After a little while the rear end started to slightly bang a little... I pulled over and noticed rear end fluid was leaking from the joint where the driveshaft meets the rear end. That seal seems to be gone. There is rear end fluid EVERYWHERE, and it doesnt seem like there is much, if any, left in the rear end. Do you guys think that something is majorly wrong inside, and I need a rebuild, or that that seal is gone, and I need to replace it, and refill the rear end? Any help would be GREAT guys. I really appreciate it.
Thank you.
Old 09-27-2011, 08:38 PM
scmedic09's Avatar
scmedic09 scmedic09 is offline
Vehicle: 2010 dodge ram
Color: Brillant Black
Rep:168
scmedic09 has a spectacular aura aboutscmedic09 has a spectacular aura about
hey sorry about the miss fortune, but this EXACT same thing happened to me 10 days ago, only i have a 2010. the dealer had to replace all the gears,pinion gear, bearings seals, and axle fluid, and they even threw n a new cover...this is just my situation, but like i said the exact same thing happened, you perfectly described my drive! hope this helps
Old 09-28-2011, 04:11 AM
Damn... That is something i didnt want to hear. Im thinking about refilling the rear end and driving it around the block to see if the noises are still there, or the noises were only there because i was running low on fluid. The truck still does move. This sucks......
Old 09-28-2011, 08:00 AM
Ted's Avatar
Ted Ted is offline
Vehicle: 2001 Sport Dodge 1500 5.9L
Ted is on a distinguished road
You should plan on getting out your BIG wallet. My set of gears and parts was $1600 but I had a friend do it. He said the dealers would be in the $3K range. My 2001 only had 31K on the clock when that happened. It has 51K on it now and no problems......so far.
Old 09-28-2011, 11:19 AM
Okay... Added some fluid and took it for a 10mph drive. It does still whine, and it bangs going into reverse or drive from park. It looks like something has gone on the inside. Does anyone know if they sell a kit for a rebuild on this rear axle?
Old 09-28-2011, 07:38 PM
scmedic09's Avatar
Rep:168
you may be able to find a whole rear end in a scrap yard, might be an option, change out the whole thing, housing and all... that could be a DIY job, but a rear-end swap out, if you have no experience id get a reputable shop to do it (not sure how mechanically inclined you may be :P)
Old 10-01-2011, 12:39 PM
jssmith76's Avatar
jssmith76 jssmith76 is offline
Vehicle: 2009 Dodge Ram 1500
Color: Sunburst Orange
Rep:26
jssmith76 is on a distinguished road
Send a message via MSN to jssmith76 Send a message via Yahoo to jssmith76
This exact thing happened to me about 3 years ago on my '97. Started off with just a lil bit of noise in the backside. After a while, she was clanking and making tons of noise. I parked it, crawled under, and snapped a few pic (of which I can't find now). But, long story short, the front end of the pumpkin was really lose and almost falling out. The knuckle joint (wrong terminology) was still attaching the driveline to the pumpkin, but it was sloppy lose and all fluid had drained out.
Anyways, I was shopping around online for rebuilt rear-ends and kept finding them in the $500.00 range. One day, on Craigslist, I found a rebuilt rear-end out of a '98 for $50. I figured "wth" and grabbed it. If it was crap, I only wasted $50. Anyways, got the truck to a buddies house by removing the driveline, and slapping the truck into 4 wheel drive (front wheel drive at that point). He looked over the rear-end and found out I had bought a professionally rebuilt rear-end. So I got really lucky with that instance.
But, now that my long story short has turned into a long story, I found it alot easier buying a whole rear-end as opposed to opening up and replacing everything. Of course, at that same moment, we replaced the brakes while everything was apart. But, it was really helpful having someone that knew what they were doing too.
Hope this helps,
Josh
Thanks,
Josh
2009 Ram 1500 Sport 4x2 Quad Cab, Sunburst Orange - Bone Stock
Old 10-01-2011, 01:34 PM
Rep:2946
sounds like at a minimum, you will need to get the pinion seal replaced
you can borrow or buy the tools & the correct parts, or take it to a shop
A shop will pull the drive shaft & inspect the U-joints, the U-joint could be the noise maker
Then likely they will spin a tire to see if the noise is coming from the rear end
If there is no noise in the rear end, they will quickly replace the pinion seal & the U-joint & you are on the road
Otherwise its time to go deeper into your wallet
Use a shop that gives you some kind of warranty on the work
Proper shimming is a must when your working on the differential
New Recall k36 found it today at Dodge dealer - REAR AXLE FLUID DRAIN-BACK FLOW RESTRICTOR - Pic RAMTX 2011 Dodge Ram Forum 131 09-23-2011 10:36 PM
leaking power steering fluid caseyfolkman 5.9L V8 Specific Topics 11 02-02-2011 06:14 PM
brake fluid leaking bad! npoe25 5.9L V8 Specific Topics 6 06-19-2010 03:18 PM
Rear Diff fluid ?? trainplanemech Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 5 04-03-2010 09:29 AM
Changed rear diff fluid with 80w90. now what? cnshough Oil Change 5 01-25-2010 09:24 PM
